So if I remove the IPv6, will it work? And if yes, how can i do that?
So probably my original diagnosis about IPv6 was right! It may take some time for your DNS changes to propagate to your computer so that your machine stops trying to connect via IPv6.
Okay, then I’ll wait and make a post, if it works. Thank you veery much for your time and help guys!
I think OP was rebooting their sever when I was checking the IPv4
It's already gone: imagineclan.de | DNSViz
But DNS servers can have the just removed AAAA record cached for the TTL time. So just wait a little bit
Is there a way to add the subdomain pointing the vServer of my friend again without getting an error again?
I suspect that the nature and cause of that error are somewhat different, so if you add it back and then discuss it here, we should be able to help figure out what’s going on.
Okay, thank you very much!
