I am completely new to this forum and its topic. I installed an SSL certificate on my domain mrjozzer.com. It was installed correctly. The Let's Debug test I ran, confirmed it is working correctly.
But when I open my domain in a browser it says the connection is unsafe. What can I do to get a correct https connection?
Thanks Jorrit
You just have to add a redirect to https://www.mrjozzer.com/
If you use Certbot, run:
certbot enhance --redirect
Hi @mrjozzer, and welcome to the LE community forum
You might also want to check your site for mixed content.
Try using: Why No Padlock?
