Hello everyone,
this is my 1st post in this website and probably the 3d in my whole life so not sure if its all good,
anyway,
I bought a domain: www.dreadd.org from godaddy, the domain is hosted on 000webhost, the website is just a prototype and it came out of wordpress.org.
Since both godaddy and 000webhost do not offer a Free ssl encryption, I decided to get a quick/free one with Cloudflare, i configured all i had to configure (dns, godaddy servername points cloudflare, cname and mx record) , updated the url from http to https (and vice versa) on wordpress settings–> general , installed both cloudflare and really simple ssl (which seems perfectly working) plugins in my wordpress site, but still, www.dreadd.org has a certificate but no secure connection.
Any help ? thanks a lot guys…
PS: all the services i got are FREE except the domain bought.
The cert at the IP for www.dreadd.org and dreadd.org does not cover those names.
It does however cover the CNAME
dreadd.000webhostapp.com via
*.000webhostapp.com
But even that site redirects to https://www.dreadd.org/ which doesn’t have a cert to cover that name.
Also worth mentioning, each FQDN seems to return a different set of IPs.
Hi @chalkrave
This is a site for supporting users of let’s encrypt
As you are using Clouflare I would suggest research in to that platform or contacting Clouflare
There are a lot of volunteers on this site and I personally don’t believe its fair to ask for help in this case.
You can also try a more generic forum such as StackExchange Encryption forums which are more generalised
Andrei
https://crt.sh/?q=dreadd.org
Your site hosted at 000webhost.com, pls login to your wordpress admin dashboard and change the primary domain name.
