My domain is: https://www.refreshskinscience.com/
I ran this command: SSL not working in ios devices
It produced this output: The connection is not private
My web server is (include version): AWS lightsail Bitnami WordPress
I using aws lightsail server
9peppe
January 30, 2022, 9:18am
2
It doesn't work on firefox either. Your certificate has been revoked. Get a new one.
The SSL working fine on windows and android. It shows valid up to 12-4-2022
Use our fast SSL Checker will help you troubleshoot common SSL Certificate installation problems on your server including verifying that the correct certificate is installed, valid, and properly trusted.
9peppe
January 30, 2022, 9:46am
4
That's because they don't check for revocations. Replace your certificate.
rg305
January 30, 2022, 6:36pm
5
Hi @nirmalk10 and welcome to the LE community forum
Have you tried renewing the cert (replacing that one with a new one) ?
[at LE, they are always FREE FREE FREE FREE FREE FREE FREE- LOL]
Hi Guys,
I will replace the certificate with the new one. It started working. Thanks for your reply and support.Thanks again.
schoen
January 31, 2022, 9:06pm
7
Huh, we should ask the SSL Shopper people to include a check for revocation status.
It's not a very common problem, but it is a common problem this week because Let's Encrypt had to revoke (I think) hundreds of thousands of certificates unexpectedly.
Edit: it seems challenging to contact them, though!
Ouch
@nirmalk10 In the future, could use a site like this instead:
system
Closed
March 2, 2022, 9:25pm
9
