SSL Certificates not working/missing
Hello Everybody
Today I configured a mailcow server for sending emails and now the ssl certificates are not working. I tested the TLS Connection with a Tool named “TLS Receiver Test” > (http://www.checktls.com/perl/TestReceiver.pl) and I got the error “Cert OK - failed”. Does anyone know how to fix or manually add the certificates to the webspace.
My domain is: mail.teamquantos.net, teamquantos.net
It produced this output: http://prntscr.com/ecvrx6
My operating system is (include version): Debian 8
My web server is (include version): apache2
This comment and the next one after it might be helpful: https://github.com/andryyy/mailcow/issues/158#issuecomment-175161464
Before we can help you in any way, we need to know how you configured the mailcow server.
Most importantly: did you set use_lets_encrypt="yes" in mailcow.config before you installed mailcow?
According to the mailcow [readme]https://github.com/andryyy/mailcow#installation[/], you can try ./install -s again if it failed to get a certificate earlier.
