Ssl certificate renewal issue
My domain is: coinapi.battleworld.game
I ran this command:certbot renew --webroot --cert-name "coinapi.battleworld.game"
It produced this output:Attempting to renew cert (coinapi.battleworld.game) from /etc/letsencrypt/renewal/coinapi.battleworld.game.conf produced an unexpected error: Failed authorization procedure. coinapi.battleworld.game (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: 139.59.92.90: Invalid response from https://coinapi.battleworld.game/.well-known/acme-challenge/ZGRA5C-r_k89iBLre0UFtEU54aEnlhshAZ9440TJy98: 404. Skipping.
/etc/letsencrypt/live/coinapi.battleworld.game/fullchain.pem (failure)
The operating system my web server runs on is (include version):debain
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 0.31.0
Check your nginx config. You're either blocking access to .well-known or you set the wrong webroot directory.
i have it,
# ACME http challenges
      root /var/www/html;     # matches name in certbot webroot folder
    # Redirect all others
still i have same issue
Failed authorization procedure. coinapi.battleworld.game (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: 139.59.92.90: Invalid response from https://coinapi.battleworld.game/.well-known/acme-challenge/EOBmd3XfPDqqFyRdtT8K1glOdkn1KxIoOVVqfU2ctEg: 404
Can you upload the log file from one of these failures
/var/log/letsencrypt/letsencrypt.log
You may need to copy it to a .txt file to upload it.
Or, just copy/paste the entire log here. Please put 3 backticks before and after the output like this:
log data
The failure is via HTTPS, which implies that the HTTP challenge request was heard and redirected.
curl -Ii http://coinapi.battleworld.game/.well-known/acme-challenge/Test_File-1234
Server: nginx/1.14.2
Date: Wed, 28 Sep 2022 16:13:11 GMT
Content-Type: text/html
Content-Length: 185
Location: https://coinapi.battleworld.game/.well-known/acme-challenge/Test_File-1234
Please post the entire nginx config:
nginx -T
certbot.renewal:All renewal attempts failed. The following certs could not be renewed:
2022-09-29 04:00:04,807:ERROR:certbot.renewal: /etc/letsencrypt/live/coinapi.amechain.io/fullchain.pem (failure)
2022-09-29 04:00:04,807:DEBUG:certbot.log:Exiting abnormally:
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.31.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1365, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1272, in renew
renewal.handle_renewal_request(config)
File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 490, in handle_renewal_request
len(renew_failures), len(parse_failures)))
certbot.errors.Error: 3 renew failure(s), 0 parse failure(s)
output of nginx -T
nginx: [emerg] "server" directive is not allowed here in /etc/nginx/sites-enabled/amechain.conf:21
nginx: configuration file /etc/nginx/nginx.conf test failed
Please show this file or fix it:
listen 80;
server_name coinapi.battleworld.game;
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /etc/letsencrypt/live/coinapi.battleworld.game/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/coinapi.battleworld.game/privkey.pem;
ssl_session_timeout 1d;
ssl_session_cache shared:MozSSL:10m; # about 40000 sessions
ssl_session_tickets off;
# curl https://ssl-config.mozilla.org/ffdhe2048.txt > /path/to/dhparam
# ssl_dhparam /etc/nginx/ssl/dhparam;
# intermediate configuration
ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
ssl_prefer_server_ciphers off;
# HSTS (ngx_http_headers_module is required) (63072000 seconds)
add_header Strict-Transport-Security "max-age=63072000" always;
ssl_trusted_certificate /etc/letsencrypt/live/coinapi.battleworld.game/chain.pem;
# OCSP stapling
ssl_stapling on;
ssl_stapling_verify on;
resolver 8.8.8.8 8.8.4.4 valid=300s;
resolver_timeout 5s;
include proxy_params;
proxy_pass http://127.0.0.1:3454;
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /usr/share/nginx/html;
access_log /var/log/nginx/coinapi.battleworld.game.access;
error_log /var/log/nginx/coinapi.battleworld.game.error;
Looks like you might be missing a closing } for the first server block in that file. Should be one right after this section. It might be a formatting problem but just check all your { and } are equally paired.
I wanted to see the entire log. You only posted a small fragment. That was not helpful. If this bracket problem fixes the syntax error please show either nginx -T (all of it) or show the log as I previously described.
