SSL certificate renewal failure for Icecast 2
radio.exploradio.fr
sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/radio.exploradio.fr.conf
Simulating renewal of an existing certificate for radio.exploradio.fr
Failed to renew certificate radio.exploradio.fr with error: Couldn't create root for renew_hook http-01 challenge responses: [Errno 2] No such file or directory: 'cat /etc'
All simulated renewals failed. The following certificates could not be renewed:
  /etc/letsencrypt/live/radio.exploradio.fr/fullchain.pem (failure)
My web server is (include version): Icecast 2.4.4
The operating system my web server runs on is (include version): Ubuntu 24.04.1 LTS
My hosting provider, if applicable, is: [Ovh] (Cloud Computing & HĂ©bergement Web | OVHcloud France)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
If needed, the Renewal file: /etc/letsencrypt/renewal/radio.exploradio.fr.conf
version = 2.9.0
archive_dir = /etc/letsencrypt/archive/radio.exploradio.fr
cert = /etc/letsencrypt/live/radio.exploradio.fr/cert.pem
privkey = /etc/letsencrypt/live/radio.exploradio.fr/privkey.pem
chain = /etc/letsencrypt/live/radio.exploradio.fr/chain.pem
fullchain = /etc/letsencrypt/live/radio.exploradio.fr/fullchain.pem
[renewalparams]
account = 1a616e669395a5ebf1ef359c72e1c2b8
authenticator = webroot
key_type = ecdsa
webroot_path = /usr/share/icecast2/web,
[[webroot_map]]
renew_hook = cat /etc/letsencrypt/live/radio.exploradio.fr/fullchain.pem /etc/letsencrypt/live/radio.exploradio.fr/privkey.pem | sudo tee /etc/icecast2/bundle.pem && service icecast2 restart
I am the one who added to this file the last line :
I was following this guide to get succesfully an SSL certificate, but the renewal process validation failed: Icecast HTTPS/SSL with Let's Encrypt: Setup Guide - Media Realm
I can also provide if needed the certbot debug log file content. Please just tell me if it safe to share it or if I should not copy/paste some parts of it.
Thank you so much for your help.
That line should not be within the webroot_map section. It belongs in the renewalparams section. Such as after key_type
Was there previously a line in the webroot_map section? I don't know if Certbot requires one but I have one in a renewal profile I recently created.
We recommend not to make manual changes to these renewal config files. Very minor incorrect entries can cause significant problems. Sometimes even incorrect new-line characters and such.
With your version of Certbot you can use the reconfigure command. See
sudo certbot help reconfigure
Any version of Certbot will re-make the renewal profile just by repeating the original command with any new options.
Lastly, I did not test your long hook command but I personally prefer putting more complex series of commands in a script and invoke the script instead. This gives flexibility of adding things like logger or echo commands in the script to validate operation. You also don't have to modify Certbot profiles for routine system changes.
What is the <listen-socket>, see Configuration File - Icecast Docs, for the Icecast server?
Also it seems that Apache is the server for your Icecast, correct?
$ curl -k -Ii http://radio.exploradio.fr/.well-known/acme-challenge/sometestfile
HTTP/1.1 404 Not Found
Date: Tue, 26 Nov 2024 22:04:47 GMT
Server: Apache/2.4.58 (Ubuntu)
Edit
Here is a list of issued certificates crt.sh | radio.exploradio.fr, the latest being 2024-11-19.
Edit 2
From here Icecast HTTPS/SSL with Let's Encrypt: Setup Guide - Media Realm (the link you provided), this is bad advice apt-get install certbot.
Instead see Get Certbot — Certbot 3.0.1 documentation
Thank you very much for your answers and your help.
Sorry for this long answer.
 <listen-socket>
        <port>8443</port>
        <ssl>1</ssl>
    </listen-socket>
also, in the <path> I have: <ssl-certificate>/etc/icecast2/bundle.pem</ssl-certificate>
you can listen to the https Icecast flow on radio.exploradio.fr:8443
My server seems to be Apache: Do you think my webroot_path in my .conf file should be Apache too then? My objective is to have https on my Icecast page on port 8443 (radio.exploradio.fr:8443), that's why the webroot_path is Icecast.
I uninstalled Certbot from apt and installed the snap one. I'm currently running certbot 3.0.1
Should I put my renew_hook between the key-type section en webroot_map section? I did not try that one yet.
Nothing more if I do not mistake
I'm sorry, I'm a newbie, I am not sure to correctly understand how to use it yet (directly in the script on in command line) and what is the purpose: reconfigure my renew .conf file?
I created a script file which I put in /home/ubuntu with my commands line and put on the last line of my renew .conf file:
renew_hook = ./home/ubuntu/myscript.sh
Here is the result of sudo certbot renew --dry-run -v
Certificate not due for renewal, but simulating renewal for dry run
http-01 challenge for radio.exploradio.fr
Using the webroot path /usr/share/icecast2/web for all unmatched domains.
Failed to renew certificate radio.exploradio.fr with error: Couldn't create root for renew_hook http-01 challenge responses: [Errno 2] No such file or directory: 'home/ubuntu'
Then, I deleted the last renew_hook line to check the original renew .conf file and I get this when sudo certbot renew --dry-run -v
Challenge failed for domain radio.exploradio.fr
  Domain: radio.exploradio.fr
  Type:   unauthorized
  Detail: 54.36.183.156: Invalid response from http://radio.exploradio.fr/.well-known/acme-challenge/KOKkoq3CL1ZBXKVtlB_quyJgQJ53fr9qZErUZ6qXoys: 404
Failed to renew certificate radio.exploradio.fr with error: Some challenges have failed.
Does it mean that my original file is already not working, before I had any renew_hook, if I did not break anything meanwhile of course.
Again, thanks a lot!
Hello again,
I might have found a solution (or a false solution).
I followed @MikeMcQ advice and put my renew_hook line before the webroot_path line in my certbot renew .conf file.
Then I changed the webroot_path from Icecast to Apache (/var/www/html/) since my Apache is the one "listenning" on port 80.
version = 2.9.0
[renewalparams]
key_type = ecdsa
renew_hook = ./home/ubuntu/exploradio/ScriptCertbotrenew_hook.sh
webroot_path = /var/www/html/,
[[webroot_map]]
The script in the file /home/ubuntu/exploradio/ScriptCertbotrenew_hook.sh includes:
#!/bin/bash
sudo cat /etc/letsencrypt/live/radio.exploradio.fr/fullchain.pem /etc/letsencrypt/live/radio.exploradio.fr/privkey.pem | sudo tee /etc/icecast2/bundle.pem && service icecast2 restart
Idon't know if the script work but I hope so.
It turned out that the sudo certbot renew --dry-run command went well:
Congratulations, all simulated renewals succeeded:
  /etc/letsencrypt/live/radio.exploradio.fr/fullchain.pem (success)
I just hope now that should be enough to allow https on my Icecast2 flow on port 8443: radio.exploradio.fr:8443
Am I right or am I mistaking?
Thanks again.
You should not have a period at the start of that path. That means start at the current directory and look for path within it of /home/...
To test a deploy-hook with --dry-run you need to do
sudo certbot renew --dry-run --run-deploy-hooks
By default, dry-run does not run deploy-hooks since a cert was not created by --dry-run
See: User Guide — Certbot 3.1.0.dev0 documentation
Yes, to properly update the renewal .conf file. It will also run a -dry-run validation before applying changes. Just run: sudo certbot help reconfigure for instructions
That said, I think your renewal profile is probably good now. Keep this in mind for future.
I see a valid connection on port 8443. Is it working for you?
Thank you very much for your help.
I did sudo certbot renew --dry-run --run-deploy-hooks and had some issue in deed,
Hook 'deploy-hook' reported error code 127
Hook 'deploy-hook' ran with error output:
 /bin/sh: 1: ./home/ubuntu/exploradio/ScriptCertbotrenew_hook.sh: not found
So, as you told me, I deleted the "." before my path/to/script.sh in my renew_hook line and re-run the command without any trouble that time: I got the 'deploy-hook' output I was looking for.
I do have for now SSL on my port 8443. I hope that for the certificate renewal, it will be the same. Otherwise, I should open a new ticket.
Once again, thank you very much for your kind help and time to explain how to configure correctly my file and run out of trouble!
Hi @Exploradio,
The HTTP-01 challenge states "It only accepts redirects to “http:” or “https:”, and only to ports 80 or 443."
You should be fine as long as you do not redirect to HTTPS since you have Port 443 close and the challenge cannot work being redirected to port 8443.
Hi @Bruce5051,
Thank you for you message.
If I understand well (which I'm not sure), that's why I'm using the following script as renew_hook in my renewal certbot .conf file:
#!/bin/bash
That way, I suppose my Icecast2 should be able to use the ssl certificate on the port 8443 as settled in my Icecast2 configuration file.
<listen-socket>
        <port>8443</port>
        <ssl>1</ssl>
    </listen-socket>
It's working for now, I just don't really understand how. If it doesn't work for the renewal, I guess I should try to configure my Icecast to listen on port 443 for SSL and then configure my webroot_path in certbot renew .conf file with Icecast one.
Thanks for your help, it's well appreciated
Would it not be much less complex to simply reverse-proxy Icecast with Apache and handle all things TLS with Apache?
Yes it should; and you can see it here https://decoder.link/sslchecker/radio.exploradio.fr/8443 using this certificate crt.sh | 15542634369
Please see:
