Could not issue an SSL/TLS certificate for saintjosephbilimora.com
Details
Could not request a Let's Encrypt SSL/TLS certificate for saintjosephbilimora.com.
Go to http://mail.saintjosephbilimora.com/.well-known/acme-challenge/k_MrNAS9qBBCEhJG54oTvaI0bNoC_gWJZcktKH8561s
and check if the authorization token's URL accepts external requests. Alternatively, use a third-party service like letsdebug.net to check the saintjosephbilimora.com to meet the Let's Encrypt requirements.
If it is, try to request the certificate again. If the token is not available, there may be an issue with your DNS configuration.
Your domain in Plesk is hosted on the IP address(es): , but the DNS challenge used another IP: 199.79.62.51.
Make sure that the IP address(es) specified in the domain's DNS zone match the IP address(es) the domain is hosted on, and that port 80 is open and reachable in both local and external firewalls.
If it does not help or if you cannot find an issue with your DNS configuration, use this KB article
