Hi Team,
SSL certificate was not renewed and I am able to see the below errors in letsencrypt logs
My domain is: www.icds-cas.gov.in
It produced this error in logs:
2019-11-06 00:49:33,151:DEBUG:certbot.renewal:Traceback was:
File “/usr/lib/python3/dist-packages/certbot/renewal.py”, line 430, in handle_renewal_request
main.renew_cert(lineage_config, plugins, renewal_candidate)
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1197, in renew_cert
renewed_lineage = _get_and_save_cert(le_client, config, lineage=lineage)
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 115, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File “/usr/lib/python3/dist-packages/certbot/renewal.py”, line 305, in renew_cert
new_cert, new_chain, new_key, _ = le_client.obtain_certificate(domains, new_key)
File “/usr/lib/python3/dist-packages/certbot/client.py”, line 334, in obtain_certificate
File “/usr/lib/python3/dist-packages/certbot/client.py”, line 370, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 82, in handle_authorizations
self._respond(aauthzrs, resp, best_effort)
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 155, in _respond
self._poll_challenges(aauthzrs, chall_update, best_effort)
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 226, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
certbot.errors.FailedChallenges: Failed authorization procedure. icds-cas.gov.in (http-01): urn:ietf:params:acme:error:caa :: CAA record for icds-cas.gov.in prevents issuance, www.icds-cas.gov.in (http-01): urn:ietf:params:acme:error:caa :: CAA record for www.icds-cas.gov.in prevents issuance
2019-11-06 00:49:33,152:ERROR:certbot.renewal:All renewal attempts failed. The following certs could not be renewed:
2019-11-06 00:49:33,153:ERROR:certbot.renewal: /etc/letsencrypt/live/www.icds-cas.gov.in/fullchain.pem (failure)
2019-11-06 00:49:33,153:DEBUG:certbot.log:Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==0.26.1’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1364, in main
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1276, in renew
renewal.handle_renewal_request(config)
File “/usr/lib/python3/dist-packages/certbot/renewal.py”, line 455, in handle_renewal_request
len(renew_failures), len(parse_failures)))
certbot.errors.Error: 1 renew failure(s), 0 parse failure(s)
The operating system my web server runs on is (include version): ubuntu 14.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.26.1
Thanks,
Sanjay
