There is an older certificate
CN=summitstonehealth.org
12.06.2019
10.09.2019
expires in 62 days ipv6.summitstonehealth.org,
mail.summitstonehealth.org,
summitstonehealth.org, www.summitstonehealth.org - 4 entries
But there
| Issuer | not before | not after | Domain names | LE-Duplicate | next LE |
| Let's Encrypt Authority X3 | 2019-07-10 | 2019-10-08 | *.summitstonehealth.org - 1 entries | duplicate nr. 1 | |
| Let's Encrypt Authority X3 | 2019-06-12 | 2019-09-10 | ipv6.summitstonehealth.org, mail.summitstonehealth.org, summitstonehealth.org, www.summitstonehealth.org - 4 entries |
is a new wildcard certificate.
That looks good, now you have found the correct place.
And the TXT entry is new ( https://check-your-website.server-daten.de/?q=summitstonehealth.org#txt ):
12. TXT - Entries
| Domainname | TXT Entry | Status | ∑ Queries | ∑ Timeout |
| summitstonehealth.org | MS=ms16979106 | ok | 1 | 0 |
| summitstonehealth.org | v=spf1 include:spf.protection.outlook.com -all | ok | 1 | 0 |
| summitstonehealth.org | MS=ms53176966 | ok | 1 | 0 |
| www.summitstonehealth.org | MS=ms53176966 | ok | 1 | 0 |
| www.summitstonehealth.org | v=spf1 include:spf.protection.outlook.com -all | ok | 1 | 0 |
| www.summitstonehealth.org | MS=ms16979106 | ok | 1 | 0 |
| _acme-challenge.summitstonehealth.org | Mnue32k9JhK7RKWWQ0TqQiHYdz69aX3V0c4XjmLSrBI | looks good | 1 | 0 |
| _acme-challenge.www.summitstonehealth.org | TW3FBpEyjSuEJBYhh5Kiad4P_LfhEpBgMkbMqA8Fzrg | looks good |
But one thing isn't good:
You have created a certificate with *.summitstonehealth.org. But you should create a certificate with both domain names *.summitstonehealth.org summitstonehealth.org. So you can use the certificate with the main domain.
And you should fix your wrong ipv6 configuration.
