OK, I created the certificate for the domain, no probblem, but each of the websites came up with warnings, so I created a certificate for each.
It works perfectly.
Now, I'm moving the entire Centos-7 server to Alma Linux. I've set it up, everything is working. I copied the /etc/httpd/conf/httpd.conf and the files (including SSL Certs) for each of the Forums.
Now as far as I read, I have to copy the entire /etc/letsencrypt folder and all the files (preserving symbolic links) to the new Alma computer.
I can't!
It won't allow me to transfer them with Filezilla to my home directory so I can copy them to the /etc/letsencrypt folder on the new server.
How do I do this? Both are VMWare Virtual machines on the same host and the same datastore.
I fixed that, It's working. THIS is my problem now
Tried to retstart httpd
Response:
Process: 11779 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
In my .conf file for the forum I have these three lines
RewriteCond %{SERVER_NAME} =server1.MyDomainFQDN [OR]
These files were copied from the OLD server. How do I set SERVER_NAME or see what it curently is? Could this be the problem?
systemctl start httpd
Job for httpd.service failed because the control process exited with error code.
See "systemctl status httpd.service" and "journalctl -xe" for details.
[root@alma-86 /]# systemctl status -l httpd
● httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2022-07-19 22:10:56 CEST; 3s ago
Docs: man:httpd.service(8)
Process: 12370 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 12370 (code=exited, status=1/FAILURE)
Jul 19 22:10:55 systemd[1]: Starting The Apache HTTP Server...
Jul 19 22:10:55 httpd[12370]: httpd: Syntax error on line 94 of /etc/httpd/conf/httpd.conf:>
Jul 19 22:10:56 systemd[1]: httpd.service: Main process exited, code=exited, status=1/FAILU>
Jul 19 22:10:56 systemd[1]: httpd.service: Failed with result 'exit-code'.
Jul 19 22:10:56 systemd[1]: Failed to start The Apache HTTP Server.
is the name of my server.
Active: failed (Result: exit-code) since Tue 2022-07-19 22:10:56 CEST; 25min ago
The path exists and theserver1, server2 .conf files are in there. You must know that. So if I comment the line out what's the point, then I have no webservers at all so the entire exercise is pointless.
As I'm starting to see this. I have three options. (a) just leave the entire thing on CentOS 7
or (b) revoke all the certificates and start over or (c) I restore my new Alma Linux machine from backup (yes I made a backup before I started) and then someone who knows Alma/Rocjky/Centos 8 servers and how to transfer the Certificates gives me a step by step WORKING solution.
It goes away!
In conf.d are the following files:
autoindex.conf,
fcgid.conf,
le-redirect-MyDomainFQDN,
manual.conf,
ssl.conf,
server1.conf,bak,
server2.conf.bak,
server1-le-ssl.conf.bak,
server2-le-ssl.conf.bak,
userdir.conf,
welcome.conf,
server2.conf.bak
and because I know that your next advice, I already tried as you can see, I renamed the two server files and the le-ssl.conf.bak
IT still fails same message
Remeber I copied these files from the old CentoOS 7 server
That solved part of the problem because some of the file had the wrong owner (don't ask me why, I have NO idea)
-rw-rw-r-- 1 me me 254 Jul 19 17:29 le-redirect-MyDomainFQDN.conf
-rw-rw-r-- 1 me me 9726 Jul 19 17:29 ssl.conf
-rw-rw-r-- 1 me me 797 Jul 19 17:29 server2-le-ssl.conf
-rw-rw-r-- 1 me me 780 Jul 19 17:29 server1-le-ssl.conf
-rw-r--r-- 1 root root 568 Jul 19 22:18 server1.conf
I ran chown -R root:root /etc/httpd/conf.d
then systemctl start httpd worked fine and status shows it running BUT
letsencrypt renew --dry-run
Returns
Failed to renew certificate MyDomainFQDN with error: The requested apache plugin does not appear to be installed
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/MyDomainFQDN/fullchain.pem (failure)
OK. I got tired of messing around and getting nowhere fast.
Here is what I've done.
Restore the new Alma Linux 8.6 new machine from backup.
Copied everything WITHOUT any SSL to the new machine.
I made sure that all the forums and websites worked using http.
Busy Backing up again now eberything is working.
What I need now, is the SIMPLEST possible waay to transfer the SSL Certificates and autoinstall from the OLD Centos 7.3 Server to the new Alma 8.6 server.
I have not yet installed certbot or anything whatsoever to do with SSL,
If someone can now give me a WORKING step by step, it would be greatly appreciated.
I'm not using CPanel. it on one of our own server in the server room. It's all on VMWare 6.0.
