My domain is: https://vle.noroff.no/
I ran this command: I have installed ovirt version 4 and setup Lets Encrypt using certbot.
The SSL encryption is working as the Lock shows up and I have run https://www.ssllabs.com.
It produced this output: When I browse to the application, I get the following error:
sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
When I run https://www.ssllabs.com, it initially says there is a name mismatch, but I am not sure where that is or how to fix that.
The operating system my web server runs on is (include version): CentOS 7
My hosting provider, if applicable, is: self hosted
Edit: I had the thought that it might be related to java, so I have added Lets Encrypt to the truststore. When checking the truststore, I see the following:
let’sencryptauthorityx3, Sep 18, 2017, trustedCertEntry,
Certificate fingerprint (SHA1):
Which would indicate that it is in the Java truststore.
