My domain is: cte.com.br
I ran this command:Instalattion according to Let’s Encrypt Apache + Ubuntu 18.04 steps.
It produced this output:Congratulations! Cert installed.
My web server is (include version): Amazon (AWS EC2)
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
You can guide me a way to check what is blocking https to work? As described we are using a AWS EC2 instance, is there a default configuration to make this work?
Yep, happy to read you have found the solution. I don't use AWS, but there are other users with the same problem. And it's required to allow port 443 to see, if it has worked.
