Hey guys, just wanted to register a certificate for my domain which has the TLD .solutions. The domain appears in the public suffix list and I’m receiving the following error:
Error creating new authz :: Name does not end in a public suffix
My domain is: vp.solutions
I’m using nanobox to request the certificate, but this actually shouldn’t be an issue.
It also looks like you are using CloudFlare CDN; which doesn’t always act logically nor as one would expect.
So, if you encounter any problems (after the PSL problem is corrected), be sure to not overlook that piece of the puzzle in your search for a solution.
Thanks for your fast reply. When I tried to retrieve the cert I unmarked the “use cloudflare” entry in the cloudflare DNS. This should bypass cloudflare, right?
I don’t use cloudflare, so I can’t say for sure.
I can see that the name still resolves to cloudflare IPs but that may be normal and expected - I can’t say.
