Although I successfully renewed the cert via win-acme, I can no longer access my domain via https w/o receiving the 'Your connection isn't private' error message.
How may I verify my cert status, outside of win-acme?
My domain is: winvm.link:2443
I ran this command: win-acme renewal process
It produced this output: success
My web server is (include version): NGINX
The operating system my web server runs on is (include version): Windows 10
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): win-acme
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): win-acme 2.1.17.1065
Question regarding auto-renewal of certs. For the life me, I cannot recall why I had to set up my cert w/ manual renewal. If I moved to Ubuntu would I then be able to run a cron job and have the cert auto-renewed?
Ok. When I was setting up win-acme, I could not set up auto-renewal. I've re-read the instructions for, but I cannot find the criteria in order to use auto-renewal. May the issue be w/ my domain handler, NameCheap? My domain is not 'hosted' anywhere, I simply have it pointing to my VPN service static IP.
When you setup win-acme you perhaps used manual DNS validation (you mentioned namecheap and your current cert is a wildcard). If you use http validation you wouldn't need to use DNS validation (but you can't get a wildcard using http validation) but I'm guessing your ISP doesn't allow you to host stuff on normal ports.
Alternatively you could switch to another ACME client that provides a namecheap DNS provider (See also https://acmeclients.com). Note that you could probably just use certbot for this as the files it produces will work fine with nginx.
Although I fixed the issue, I am intrigued about getting the renewal process to be automatic.
It just may be that I couldn't do the validation via dns with NameCheap. I'll try Certbot. If I can't get it to work, I'll start a new specific thread herein. Thank you.
