Simple instructions for renewal
My domain is: tedagents.com
It produced this output: I don't know the command to run
My web server is (include version): Nginx
The operating system my web server runs on is (include version): Ubuntu 24
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): I don't have a version control panel.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): I am not using certbot
Did you have a question? Because with the (no) information you've given, there really isn't anything we can tell you. My crystal ball says you got an email saying your cert was about to expire. If that's really the case, all I can say is "whatever you did to get the cert, do it again."
Hello @tedcoombs, welcome to the Let's Encrypt community. :slightly_smiling_face:
Using the online tool Let's Debug yields these results https://letsdebug.net/tedagents.com/2296372
CloudflareCDN
Warning
The domain tedagents.com is being served through Cloudflare CDN. Any Let's Encrypt certificate installed on the origin server will only encrypt traffic between the server and Cloudflare. It is strongly recommended that the SSL option 'Full SSL (strict)' be enabled.
https://support.cloudflare.com/hc/en-us/articles/200170416-What-do-the-SSL-options-mean-
Specifically note: "It is strongly recommended that the SSL option 'Full SSL (strict)' be enabled."
