Setting up letsencrypt for subdomains
I've followed this toturial (https://community.hetzner.com/tutorials/server-monitoring-using-grafana-and-influxdb), to set up influxdb and grafana on my server. However, I am not sure what the _acme-challenge files need to hold. I have generated a personal DNS token from Hetzner, put it in the _acme-challenge but no luck (see below). When this token is put in, I also get incorrect TXT record.
I have also added the hetzner nameservers in the _acme-challenge files, but this also does not work. I am just trying, but perhaps someone can help me out here. Much appreciated.
www.sonnem.nl
echo <HETZNER_PERSONAL_ACCES_TOKEN> > /etc/hetzner-dns-token
certbot certonly --manual --preferred-challenges=dns --manual-auth-hook /usr/local/bin/certbot-hetzner-auth.sh --manual-cleanup-hook /usr/local/bin/certbot-hetzner-cleanup.sh -d influx.sonnem.nl -d
grafana.sonnem.nl
   Domain: grafana.sonnem.nl
   Type:   unauthorized
   Detail: Incorrect TXT record "helium.ns.hetzner.de." found at
   _acme-challenge.grafana.sonnem.nl
   Domain: influx.sonnem.nl
   Type:   unauthorized
   _acme-challenge.influx.sonnem.nl
NGINX
Ubuntu 20.0.8
Namecheap as hosting provider, server is from Hetzner. Advanced DNS as follows:
A Record
116.203.157.240
A Record
grafana
116.203.157.240
A Record
influx
116.203.157.240
TXT Record
Remove
TXT Record
no
certbot 0.40.0
Thank you very much in advance.
Well, that ain't right.
Also, could you perhaps clarify the following bit?
What exact role does Namecheap have? You say "hosting provider", which usually means the company providing either the shared hosting platform or the VPS server. But you also say the server is from Hetzner? Which one does what exactly? Especially, who's the DNS service provider?
Edit: Dug a little bit further and it seems your DNS service provider is Namecheap. Well, you obviously can't change Namecheap settings using a Hetzner token.. Also, looking at the current TXT record value, it seems you might have tried to "redirect" the TXT resource record to the "helium" nameserver of Hetzner? Not in a correct way by the way, but that doesn't matter, because if I request anything regarding your domain from helium.ns.hetzner.de, the server returns a "REFUSED" status. Which makes sense if Hetzner is just providing your the hosting server, but not the DNS service.
Note that Namecheap does have an API which would enable you to automate the dns-01 challenge, but that service has some strict requirements, which you can find here: GitHub - iHamsterball/certbot-dns-namecheap: Certbot plugin to provide dns-01 challenge support for namecheap.com
Another note: do you actually require the dns-01 challenge? Why not simply use the http-01 challenge for those two hostnames? That would make your life MUCH easier..
Thanks for your quick reply. Yes, my DNS service provider is namecheap. I would prefer the road of least resistance, if you have any better suggestions; please let me know. I do not require the dns-01 challenge, if the other what you said is simpler; I would do that. I am however, not familiar with a lot of this.
The tutorial you've followed makes it a little bit harder to "walk the easy path", as it seems it has nginx configured already, but with non-existing certificate/private key values. Making nginx actually fail to start. My suggestion is to modify part 5, "Step 5 - Install Nginx" of the tutorial as follows:
  • don't set up the proxy_pass redirects yet;
  • just make two server {} blocks using HTTP on port 80 first
    • these server blocks just need a listen and server_name directive, nothing more
  • get the certificate using sudo certbot --nginx
    • Certbot should have generated two HTTPS server blocks from the stubs you made above
    • And a redirect for HTTP to HTTPS
  • now you can modify the now HTTPS stubs to incorporate the location/proxy_pass stuff
Now, I don't have much nginx experience and perhaps the stubs require a little bit more than just listen/server_name, but I'd try the above first if I were you :slight_smile:
Awesome, thanks.
Yes, the tutorial made it all a bit harder. I have now
    server_name  grafana.sonnem.nl;
        proxy_pass           http://localhost:3000/;
    ssl_certificate /etc/letsencrypt/live/grafana.sonnem.nl/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/grafana.sonnem.nl/privkey.pem; # managed by Certbot
    if ($host = grafana.sonnem.nl) {
    } # managed by Certbot
    listen 80;
    listen [::]:80;
and your certbot worked. I did not do it for influxdb, as there was nothing to be seen there anyway. Thank you so much for your time.
Looks good! :slight_smile: Note that the Certbot team gets all the credits for developing Certbot :wink:
Also, I agree regarding influx: if you only use influx locally (i.e., 127.0.0.1/localhost) it doesn't require a certificate.
