Hi @matt233
matt233:
My domain is: trixservices.it
I ran this command: I tryed force SSL “entire site”
It produced this output: Chrome output : ERR_TOO_MANY_REDIRECTS
I don't see a loop, but two wrong redirects and one missing. Checking your 4 standard combinations:
D:\temp>download http://trixservices.it/ -h
Transfer-Encoding: chunked
Content-Type: text/html; charset=utf-8
Date: Sat, 27 Oct 2018 09:22:24 GMT
Set-Cookie: __cfduid=d858f4971d15b1b53a9155026a225e0f51540632141; expires=Sun, 27-Oct-19 09:22:21 GMT; path=/; domain=.trixservices.it; HttpOnly,ceb525ff2d260e11a1b2ef1592c8fe1d=kdkk9hsgk1cs5sl2m60vtkp8mg; path=/; HttpOnly
Expires: Wed, 17 Aug 2005 00:00:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
X-Xss-Protection: 1; mode=block
X-Content-Type-Options: nosniff
X-Request-ID: 4a95fae8ad9072a0259f2e0fb5e4938e
Server: cloudflare
CF-RAY: 47041902f0e1980a-FRA
Status: 200 OK
3187,68 milliseconds
3,19 seconds
http + non-www - no redirect. There should be a redirect to https.
D:\temp>download https://trixservices.it/ -h
SSL-Zertifikat is valide
Date: Sat, 27 Oct 2018 09:22:31 GMT
Set-Cookie: __cfduid=d15903fdb5f7f5d44c1d14b339e17833c1540632150; expires=Sun, 27-Oct-19 09:22:30 GMT; path=/; domain=.trixservices.it; HttpOnly,ceb525ff2d260e11a1b2ef1592c8fe1d=frf6rnr92bgkv1a1uvvte057cq; path=/; HttpOnly
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0, no-cache
Pragma: no-cache, no-cache
X-Request-ID: ea33bcb093be4ab580f896a7b2f925bc
Expect-CT: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct "
Server: cloudflare
CF-RAY: 4704193efc3397e0-FRA
Status: 200 OK
1364,90 milliseconds
1,36 seconds
https + non-www - no redirect, this is good.
D:\temp>download http://www.trixservices.it/ -h
X-Request-ID: 61b41f131972febb8f058bb91def4000
CF-RAY: 47041a0a712d96be-FRA
Date: Sat, 27 Oct 2018 09:23:03 GMT
Set-Cookie: __cfduid=d9c38fc47f3f9a99afbb2130b62a07dce1540632183; expires=Sun, 27-Oct-19 09:23:03 GMT; path=/; domain=.trixservices.it; HttpOnly
Server: cloudflare
Status: 301 MovedPermanently
406,16 milliseconds
0,41 seconds
This is a redirect http + www -> http + non-www, this is wrong. That should be http + www -> https + www.
D:\temp>download https://www.trixservices.it/ -h
X-Request-ID: 2612cca921b6fe597cd6bf8f1051865b
CF-RAY: 47041a77e8c0bf16-FRA
Date: Sat, 27 Oct 2018 09:23:21 GMT
Set-Cookie: __cfduid=d5cc580f2b4cb3991747ec3c172b557571540632200; expires=Sun, 27-Oct-19 09:23:20 GMT; path=/; domain=.trixservices.it; HttpOnly
Server: cloudflare
498,82 milliseconds
0,50 seconds
This is definitively wrong: https + www to http. https should never redirect to http.
Then check your mixed content. FireFox or Chrome (Desktop), Ctrl + Shift + I, then the console. There you see the wrong links.
http://trixservices.it/media/plg_jchoptimize/cache/6fdc642 ...
So CSS- and JavaScript files are missing.
