On that note, what version of cURL
, and OpenSSL, are you running?
curl --version
openssl version
Just realized neither curl nor OpenSSL is installed on the server. Could it be the reason that cause the error message?
Your PHP seems to be having a functional cURL library, so I don't think your recent findings are relevant.
Please look into CURLOPT_CAPATH
as I suggested earlier.
An alternative option would be CURLOPT_CAINFO
Also, it might be a good idea to check if it's a PHP issue or not by running curl
from the command line on the server which is also serving your PHP file.
HI there,
Finally got it fixed by downloading an update cert from curl - Extract CA Certs from Mozilla and updating ```
curl.cainfo in php.ini.
