Secure Connection Failed
Hello, my root domain has https setup, and I tried to setup a subdomain but it fails
An error occurred during a connection to cloud.fluffykillers.com. Cannot communicate securely with peer: no common encryption algorithm(s). Error code: SSL_ERROR_NO_CYPHER_OVERLAP
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
What is the webserver you're using? Can you share its configuration? This looks like an error related to not offering any ciphersuites that the client you're testing with supports.
Umm hey, I solved it by myself, apparently it has problems with CNAME records, i had to use A records instead
