Hi Guys I have a mail server (Mailserve by Cutedge) and a Webserver (Abyss Webserver) on the same MacOs server machine.
Both the software have built in a mechanism to issue Letsencrypt certificates. The webserver issues the certificates without problem, but the mailserver can not issue them as it can not use the port 80 which is reserved by the webserver.
In theory the webserver should be turned off so the mailserver can take the port 80 and issue the certificate. Practically this is almost impossible as there is no way to know how much time the certificate will take to be issued. Is there a way for the web server certificate to be used by the mailserver also?
My domain is: prismastore.cy
My web server is (include version): Abyss Webserver for Mac latest version
The operating system my web server runs on is (include version): MacOs 12+
or certbot-auto --version
if you're using Certbot): Letsencrypt Enabler 3.04 for the mailserve
ACME-Bot
ACME-Bot is an internal component of Abyss Web Server. It is responsible of interacting with ACME compliant certification authorities such as Let's Encrypt which delivers free SSL/TLS certificates trusted by all modern browsers and HTTPS clients. ACME-Bot installs obtained certificates and renews those near expiry. It also handles HTTP-01 challenges to prove domain ownership: For that end, ACME-Bot may create a responder host listening on port 80 (by default) to reply to ACME certification authorities challenges in an automatic way.
