Rpi4 mail server certificate issue problem
My domain is: c9mail.clasystem.com
I ran this command: certbot -v certonly --standalone --rsa-key-size 4096 --agree-tos --preferred-challenges http -d c9mail.clasystem.com --dry-run
It produced this output: Certbot failed to authenticate some domains (authenticator: standalone). The Certificate Authority reported these problems:
Domain: c9mail.clasystem.com
My web server is (include version): No web server
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: Self hosted
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.30.0
I built a light traffic send-only mail server on a Raspberry Pi 4 using Postfix with a static IP.
My DNS records appear to be correct and I have A and AAAA records. I can ping the sub-domain (c9mail.clasystem.com) with ping -4 and ping -6. I have another simple web server on different machine (also static IP from same block provided by AT&T) that works ok and is secured with a cert from Letsencrypt.
It continually fails to retreive a cert due to the http-01 challenge. I can see port 80 (v6) is opening while trying to retreive and then closes several seconds later when it gives up.
It says the 'Certificate Authority failed to download the challenge files from the temporary standalone webserver started by Certbot on port 80'.
Does this temp http server run in memory or do I need to change permissions for some directory?
Thanks, any help would great
Hi @jagger, and welcome to the LE community forum :slight_smile:
LE prefers IPv6 over IPv4 when present.
Your site has both, but the IPv6 address is improper for use over the Internet:
Addresses: fe80::e65f:1ff:fe97:1cf7
           107.137.100.243
[much like 127.0.0.1, any IPv6 address that starts with fe80:: can't be reached via the Internet]
Thanks for the response rg305.
I can ping it fom outside.
There are 3 total ipv6 addr listed with 'ip a'.
the other 2 appear to be dynamic so I didn't use them.
scope global dynamic noprefixroute
scope global dynamic mngtmpaddr noprefixroute
Should I use one of those?
I tried all 3 IPv6 listed for eth0
inet6 2600:1700:eb90:4900::3e8/128 scope global dynamic noprefixroute
inet6 2600:1700:eb90:4900:e65f:1ff:fe97:1cf7/64 scope global dynamic mngtmpaddr noprefixroute
inet6 fe80::e65f:1ff:fe97:1cf7/64 scope link
I could ping all 3 from outside,
Still no joy
Besides, doesn't certbot failover to IPv4 if IPv6 fails?
I can't ping either of those IPv6 IPs.
It depends on the failure.
Can you just remove the AAAA record from DNS?
fe80::/10 = link-local unicast, so that's never going to work over the internet.
Further, I concur with Rudy here: the other 2 IPv6 addresses are not pingable from my point of view. Also, 107.137.100.243 is not pingable too.
Thanks for responding guys.
I had shut the pi off overnight as it's still vulnerable at this point. It's powered up again and pingable to
2600:1700:eb90:4900:e65f:1ff:fe97:1cf7 and 107.137.100.243 now. Rudy, I tried without the IPv6 already and got the same http-01 challenge failure.
I can ping them too. Standalone is harder to debug but can you do this?
certbot -v certonly --standalone --rsa-key-size 4096 --agree-tos --preferred-challenges http -d c9mail.clasystem.com --dry-run --debug-challenges
That addition of --debug-challenges will start standalone and pause showing you the URL to test with. Leave that running and use a different system (or window) to test that URL
Here's what I got:
URL:
http://c9mail.clasystem.com/.well-known/acme-challenge/7bmcPrFnOlbHbQoyHn-Ja8ZsMbdM5iK-JKbCoUG3obk
Expected value:
7bmcPrFnOlbHbQoyHn-Ja8ZsMbdM5iK-JKbCoUG3obk.ImS2yynK3sgvoCJ_e8_iK17n8qhgVwuD_IiqGnyJZs0
I'm not really sure how to check this-
IPv4 seems to be working (pingable), but IPv6 from my point of view not.
If it's vulnerable (what does that mean?) you shouldn't have it connected to the internet to begin with.
Good point! But it is a mail server after all and it has no SSL protection yet. Besides, is there another way of getting a cert? I'm still learning this stuff.
Is the standalone test still running? Because I don't see port 80 open to process the http request to you.
It's still running. But 80 is closed.
I let it continue till it finished, ran it again but 80 doesn't seem to open at all with that debug command and it still fails.
Is the port open in your router and NAT/forwarded to your server?
When you say port 80 does not open, how did you check that?
It's a public static IP. Not sure about NAT/forwarding
I check the port from another putty session using 'lsof -i :80' command every second while running certbot.
Do you have a router?
Use this to test while certbot standalone runs
curl -i -m5 c9mail.clasystem.com
Should see something like:
HTTP/1.0 200 OK
Server: BaseHTTP/0.6 Python/3.8.10
Date: Sat, 10 Sep 2022 14:10:33 GMT
Content-Type: text/html
ACME client standalone challenge solver
Right now I get a timeout trying to reach your domain. Something is preventing access to your server.
EDIT:
I don't know how lsof works in that case but you can try this to check the port. But, if certbot standalone did not show any error you can fairly assume it bound to port 80
sudo netstat -pant | grep -i ':80'
(should see python3 as process listening)
This is what I got:
ACME client standalone challenge solverroot@c9mail:/home/c91# curl -i -m5 c9mail .clasystem.com
HTTP/1.0 200 OK
Date: Sat, 10 Sep 2022 14:18:54 GMT
And this is what I get from the public internet (US East Coast)
curl: (28) Failed to connect to c9mail.clasystem.com port 80 after 2706 ms: Connection timed out
Did you try that command from outside your own network? Maybe even a cell phone with wifi off?
It's hardwired.
I only have a windows machine on another static IP but it doesn't like the curl command. However I can ping -6 and -4 to the 2600:1700:eb90:4900:e65f:1ff:fe97:1cf7 and 107.137.100.243
Maybe it is something to do with the router.
I take it back. I can't ping the IP6 from that windows machine
Funny thing I can ping the ipv6 addr from my local, private win10 machine.
I'll try it with my cell phone with wifi off,
ping uses ICMP which is different than using, say, curl or a browser for HTTP (using TCP)
Do you have a cell phone? Just turn off wifi and use a browser and try the URL shown by certbot standalone. Or, even just
Be sure to specify HTTP so a browser does not try HTTPS
I would remove the AAAA from DNS while you sort out basic connectivity. Once you have IPv4 working you can go back and try that again.
