Made some progress. I was able to install the certificate, but can’t login. Please check https://quantumstat.us/auth/login. If you try to login with any username and password you get
This page isn’t working
quantumstat.us didn’t send any data.
ERR_EMPTY_RESPONSE
in Chrome.
I’d appreciate the help. Below is what is in the log. It reads “mod_md support is unavailable.” Could this be the problem?
[Thu Feb 21 02:36:20.659925 2019] [ssl:info] [pid 9118:tid 139991896505280] AH01914: Configuring server quantumstat.us:443 for SSL protocol
[Thu Feb 21 02:36:20.662104 2019] [ssl:debug] [pid 9118:tid 139991896505280] ssl_engine_init.c(1701): AH10083: Init: (quantumstat.us:443) mod_md support is unavailable.
[Thu Feb 21 02:36:20.662347 2019] [ssl:debug] [pid 9118:tid 139991896505280] ssl_engine_init.c(479): AH01893: Configuring TLS extension handling
[Thu Feb 21 02:36:20.662615 2019] [ssl:debug] [pid 9118:tid 139991896505280] ssl_util_ssl.c(476): AH02412: [quantumstat.us:443] Cert matches for name ‘quantumstat.us’ [subject: CN=quantumstat.us / issuer: CN=Let’s Encrypt Authority X3,O=Let’s Encrypt,C=US / serial: 03FE51E9AEFF3533CE4E2528B14DEDB10FF9 / notbefore: Feb 21 00:00:18 2019 GMT / notafter: May 22 00:00:18 2019 GMT]
[Thu Feb 21 02:36:20.662625 2019] [ssl:info] [pid 9118:tid 139991896505280] AH02568: Certificate and private key quantumstat.us:443:0 configured from /etc/letsencrypt/live/quantumstat.us/fullchain.pem and /etc/letsencrypt/live/quantumstat.us/privkey.pem
[Thu Feb 21 02:36:20.686294 2019] [ssl:info] [pid 9119:tid 139991896505280] AH01914: Configuring server quantumstat.us:443 for SSL protocol
[Thu Feb 21 02:36:20.686319 2019] [ssl:debug] [pid 9119:tid 139991896505280] ssl_engine_init.c(1701): AH10083: Init: (quantumstat.us:443) mod_md support is unavailable.
[Thu Feb 21 02:36:20.686451 2019] [ssl:debug] [pid 9119:tid 139991896505280] ssl_engine_init.c(479): AH01893: Configuring TLS extension handling
[Thu Feb 21 02:36:20.686668 2019] [ssl:debug] [pid 9119:tid 139991896505280] ssl_util_ssl.c(476): AH02412: [quantumstat.us:443] Cert matches for name ‘quantumstat.us’ [subject: CN=quantumstat.us / issuer: CN=Let’s Encrypt Authority X3,O=Let’s Encrypt,C=US / serial: 03FE51E9AEFF3533CE4E2528B14DEDB10FF9 / notbefore: Feb 21 00:00:18 2019 GMT / notafter: May 22 00:00:18 2019 GMT]
[Thu Feb 21 02:36:20.686680 2019] [ssl:info] [pid 9119:tid 139991896505280] AH02568: Certificate and private key quantumstat.us:443:0 configured from /etc/letsencrypt/live/quantumstat.us/fullchain.pem and /etc/letsencrypt/live/quantumstat.us/privkey.pem
[Thu Feb 21 02:36:26.172337 2019] [ssl:info] [pid 9121:tid 139991757870848] [client 98.7.70.54:38615] AH01964: Connection to child 5 established (server quantumstat.us:443)
[Thu Feb 21 02:36:26.172866 2019] [socache_shmcb:debug] [pid 9121:tid 139991757870848] mod_socache_shmcb.c(532): AH00835: socache_shmcb_retrieve (0x50 -> subcache 16)
[Thu Feb 21 02:36:26.172905 2019] [socache_shmcb:debug] [pid 9121:tid 139991757870848] mod_socache_shmcb.c(917): AH00851: shmcb_subcache_retrieve found no match
[Thu Feb 21 02:36:26.172913 2019] [socache_shmcb:debug] [pid 9121:tid 139991757870848] mod_socache_shmcb.c(542): AH00836: leaving socache_shmcb_retrieve successfully
[Thu Feb 21 02:36:26.172952 2019] [ssl:debug] [pid 9121:tid 139991757870848] ssl_engine_kernel.c(2141): [client 98.7.70.54:38615] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:26.173011 2019] [ssl:debug] [pid 9121:tid 139991757870848] ssl_engine_kernel.c(2141): [client 98.7.70.54:38615] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:26.173020 2019] [core:debug] [pid 9121:tid 139991757870848] protocol.c(2314): [client 98.7.70.54:38615] AH03155: select protocol from , choices=h2,http/1.1 for server quantumstat.us
[Thu Feb 21 02:36:26.176510 2019] [ssl:info] [pid 9121:tid 139991749478144] [client 98.7.70.54:38928] AH01964: Connection to child 6 established (server quantumstat.us:443)
[Thu Feb 21 02:36:26.176737 2019] [socache_shmcb:debug] [pid 9121:tid 139991749478144] mod_socache_shmcb.c(532): AH00835: socache_shmcb_retrieve (0x02 -> subcache 2)
[Thu Feb 21 02:36:26.176755 2019] [socache_shmcb:debug] [pid 9121:tid 139991749478144] mod_socache_shmcb.c(917): AH00851: shmcb_subcache_retrieve found no match
[Thu Feb 21 02:36:26.176761 2019] [socache_shmcb:debug] [pid 9121:tid 139991749478144] mod_socache_shmcb.c(542): AH00836: leaving socache_shmcb_retrieve successfully
[Thu Feb 21 02:36:26.176779 2019] [ssl:debug] [pid 9121:tid 139991749478144] ssl_engine_kernel.c(2141): [client 98.7.70.54:38928] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:26.176823 2019] [ssl:debug] [pid 9121:tid 139991749478144] ssl_engine_kernel.c(2141): [client 98.7.70.54:38928] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:26.176831 2019] [core:debug] [pid 9121:tid 139991749478144] protocol.c(2314): [client 98.7.70.54:38928] AH03155: select protocol from , choices=h2,http/1.1 for server quantumstat.us
[Thu Feb 21 02:36:26.191444 2019] [ssl:debug] [pid 9121:tid 139991757870848] ssl_engine_kernel.c(2069): [client 98.7.70.54:38615] AH02041: Protocol: TLSv1.2, Cipher: ECDHE-RSA-CHACHA20-POLY1305 (256/256 bits)
[Thu Feb 21 02:36:26.196069 2019] [ssl:debug] [pid 9121:tid 139991749478144] ssl_engine_kernel.c(2069): [client 98.7.70.54:38928] AH02041: Protocol: TLSv1.2, Cipher: ECDHE-RSA-CHACHA20-POLY1305 (256/256 bits)
[Thu Feb 21 02:36:26.207532 2019] [ssl:debug] [pid 9121:tid 139991757870848] ssl_engine_kernel.c(377): [client 98.7.70.54:38615] AH02034: Initial (No.1) HTTPS request received for child 5 (server quantumstat.us:443)
[Thu Feb 21 02:36:26.207656 2019] [authz_core:debug] [pid 9121:tid 139991757870848] mod_authz_core.c(820): [client 98.7.70.54:38615] AH01626: authorization result of Require all granted: granted
[Thu Feb 21 02:36:26.207665 2019] [authz_core:debug] [pid 9121:tid 139991757870848] mod_authz_core.c(820): [client 98.7.70.54:38615] AH01626: authorization result of <RequireAny>: granted
[Thu Feb 21 02:36:26.207752 2019] [authz_core:debug] [pid 9121:tid 139991757870848] mod_authz_core.c(820): [client 98.7.70.54:38615] AH01626: authorization result of Require all granted: granted
[Thu Feb 21 02:36:26.207759 2019] [authz_core:debug] [pid 9121:tid 139991757870848] mod_authz_core.c(820): [client 98.7.70.54:38615] AH01626: authorization result of <RequireAny>: granted
[Thu Feb 21 02:36:26.215693 2019] [wsgi:info] [pid 9121:tid 139991757870848] [client 98.7.70.54:38615] mod_wsgi (pid=9121, process=’’, application=‘quantumstat.us|’): Loading WSGI script ‘/var/www/html/researchcenter/researchcenter.wsgi’.
[Thu Feb 21 02:36:26.785989 2019] [deflate:debug] [pid 9121:tid 139991757870848] mod_deflate.c(853): [client 98.7.70.54:38615] AH01384: Zlib: Compressed 7073 to 2116 : URL /auth/login
[Thu Feb 21 02:36:26.863440 2019] [ssl:debug] [pid 9121:tid 139991741085440] ssl_engine_kernel.c(377): [client 98.7.70.54:38615] AH02034: Subsequent (No.2) HTTPS request received for child 7 (server quantumstat.us:443), referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.863561 2019] [authz_core:debug] [pid 9121:tid 139991741085440] mod_authz_core.c(820): [client 98.7.70.54:38615] AH01626: authorization result of Require all granted: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.863570 2019] [authz_core:debug] [pid 9121:tid 139991741085440] mod_authz_core.c(820): [client 98.7.70.54:38615] AH01626: authorization result of <RequireAny>: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.864316 2019] [deflate:debug] [pid 9121:tid 139991741085440] mod_deflate.c(853): [client 98.7.70.54:38615] AH01384: Zlib: Compressed 16500 to 4325 : URL /static/css/research-center.css, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.864540 2019] [ssl:debug] [pid 9121:tid 139991749478144] ssl_engine_kernel.c(377): [client 98.7.70.54:38928] AH02034: Initial (No.1) HTTPS request received for child 6 (server quantumstat.us:443), referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.864588 2019] [authz_core:debug] [pid 9121:tid 139991749478144] mod_authz_core.c(820): [client 98.7.70.54:38928] AH01626: authorization result of Require all granted: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.864594 2019] [authz_core:debug] [pid 9121:tid 139991749478144] mod_authz_core.c(820): [client 98.7.70.54:38928] AH01626: authorization result of <RequireAny>: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.882850 2019] [ssl:debug] [pid 9121:tid 139991732692736] ssl_engine_kernel.c(377): [client 98.7.70.54:38615] AH02034: Subsequent (No.3) HTTPS request received for child 8 (server quantumstat.us:443), referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.882987 2019] [authz_core:debug] [pid 9121:tid 139991732692736] mod_authz_core.c(820): [client 98.7.70.54:38615] AH01626: authorization result of Require all granted: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.882994 2019] [authz_core:debug] [pid 9121:tid 139991732692736] mod_authz_core.c(820): [client 98.7.70.54:38615] AH01626: authorization result of <RequireAny>: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.883728 2019] [deflate:debug] [pid 9121:tid 139991732692736] mod_deflate.c(853): [client 98.7.70.54:38615] AH01384: Zlib: Compressed 19368 to 3494 : URL /static/js/research-center.js, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:26.898858 2019] [ssl:info] [pid 9122:tid 139991869302528] [client 98.7.70.54:43847] AH01964: Connection to child 64 established (server quantumstat.us:443)
[Thu Feb 21 02:36:26.899391 2019] [ssl:debug] [pid 9122:tid 139991869302528] ssl_engine_kernel.c(2141): [client 98.7.70.54:43847] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:26.899437 2019] [ssl:debug] [pid 9122:tid 139991869302528] ssl_engine_kernel.c(2141): [client 98.7.70.54:43847] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:26.899445 2019] [core:debug] [pid 9122:tid 139991869302528] protocol.c(2314): [client 98.7.70.54:43847] AH03155: select protocol from , choices=h2,http/1.1 for server quantumstat.us
[Thu Feb 21 02:36:26.918296 2019] [ssl:debug] [pid 9122:tid 139991869302528] ssl_engine_kernel.c(2069): [client 98.7.70.54:43847] AH02041: Protocol: TLSv1.2, Cipher: ECDHE-RSA-CHACHA20-POLY1305 (256/256 bits)
[Thu Feb 21 02:36:31.790837 2019] [ssl:debug] [pid 9121:tid 139991724300032] ssl_engine_io.c(1103): [client 98.7.70.54:38615] AH02001: Connection closed to child 9 with standard shutdown (server quantumstat.us:443)
[Thu Feb 21 02:36:31.790994 2019] [ssl:debug] [pid 9121:tid 139991724300032] ssl_engine_io.c(1103): [client 98.7.70.54:38928] AH02001: Connection closed to child 9 with standard shutdown (server quantumstat.us:443)
[Thu Feb 21 02:36:46.938484 2019] [reqtimeout:info] [pid 9122:tid 139991869302528] [client 98.7.70.54:43847] AH01382: Request header read timeout
[Thu Feb 21 02:36:46.938650 2019] [ssl:debug] [pid 9122:tid 139991869302528] ssl_engine_io.c(1103): [client 98.7.70.54:43847] AH02001: Connection closed to child 64 with standard shutdown (server quantumstat.us:443)
[Thu Feb 21 02:36:47.542184 2019] [ssl:info] [pid 9122:tid 139991852517120] [client 98.7.70.54:33174] AH01964: Connection to child 66 established (server quantumstat.us:443)
[Thu Feb 21 02:36:47.542485 2019] [ssl:debug] [pid 9122:tid 139991852517120] ssl_engine_kernel.c(2141): [client 98.7.70.54:33174] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:47.542511 2019] [ssl:debug] [pid 9122:tid 139991852517120] ssl_engine_kernel.c(2141): [client 98.7.70.54:33174] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:47.542516 2019] [core:debug] [pid 9122:tid 139991852517120] protocol.c(2314): [client 98.7.70.54:33174] AH03155: select protocol from , choices=h2,http/1.1 for server quantumstat.us
[Thu Feb 21 02:36:47.542673 2019] [ssl:info] [pid 9122:tid 139991774656256] [client 98.7.70.54:40193] AH01964: Connection to child 67 established (server quantumstat.us:443)
[Thu Feb 21 02:36:47.542832 2019] [ssl:debug] [pid 9122:tid 139991774656256] ssl_engine_kernel.c(2141): [client 98.7.70.54:40193] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:47.542854 2019] [ssl:debug] [pid 9122:tid 139991774656256] ssl_engine_kernel.c(2141): [client 98.7.70.54:40193] AH02043: SSL virtual host for servername quantumstat.us found
[Thu Feb 21 02:36:47.542858 2019] [core:debug] [pid 9122:tid 139991774656256] protocol.c(2314): [client 98.7.70.54:40193] AH03155: select protocol from , choices=h2,http/1.1 for server quantumstat.us
[Thu Feb 21 02:36:47.557212 2019] [ssl:debug] [pid 9122:tid 139991774656256] ssl_engine_kernel.c(2069): [client 98.7.70.54:40193] AH02041: Protocol: TLSv1.2, Cipher: ECDHE-RSA-CHACHA20-POLY1305 (256/256 bits)
[Thu Feb 21 02:36:47.557330 2019] [ssl:debug] [pid 9122:tid 139991852517120] ssl_engine_kernel.c(2069): [client 98.7.70.54:33174] AH02041: Protocol: TLSv1.2, Cipher: ECDHE-RSA-CHACHA20-POLY1305 (256/256 bits)
[Thu Feb 21 02:36:47.557446 2019] [ssl:debug] [pid 9122:tid 139991852517120] ssl_engine_kernel.c(377): [client 98.7.70.54:33174] AH02034: Initial (No.1) HTTPS request received for child 66 (server quantumstat.us:443), referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:47.557530 2019] [authz_core:debug] [pid 9122:tid 139991852517120] mod_authz_core.c(820): [client 98.7.70.54:33174] AH01626: authorization result of Require all granted: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:47.557539 2019] [authz_core:debug] [pid 9122:tid 139991852517120] mod_authz_core.c(820): [client 98.7.70.54:33174] AH01626: authorization result of <RequireAny>: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:47.557619 2019] [authz_core:debug] [pid 9122:tid 139991852517120] mod_authz_core.c(820): [client 98.7.70.54:33174] AH01626: authorization result of Require all granted: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:47.557625 2019] [authz_core:debug] [pid 9122:tid 139991852517120] mod_authz_core.c(820): [client 98.7.70.54:33174] AH01626: authorization result of <RequireAny>: granted, referer: https://quantumstat.us/auth/login?next=%2F
[Thu Feb 21 02:36:47.565686 2019] [wsgi:info] [pid 9122:tid 139991852517120] [client 98.7.70.54:33174] mod_wsgi (pid=9122, process=’’, application=‘quantumstat.us|’): Loading WSGI script ‘/var/www/html/researchcenter/researchcenter.wsgi’., referer: https://quantumstat.us/auth/login?next=%2F
