I tried gitlab.ciwise.com for several times and couldn’t get NGINX to listen on 443. I realized there are rate limits so I deleted my DNS gitlab.ciwise.com and switched to devops.ciwise.com. I then added --staging and still get unauthorized. Not sure where to go from here.
Your account credentials have been saved in your Certbot
My web server is (include version): Gitlab (NGINX embedded)
The operating system my web server runs on is (include version): Debian 8 (DigitalOcean)
My hosting provider, if applicable, is: DigitalOcean
The nginx location rule you presumably added to map https://devops.ciwise.com/.well-known/acme-challenge/ to /var/www/letsencrypt doesn’t appear to be working. A common mistake is to include .well-known/acme-challenge in the root argument while actually nginx appends that.
If you could share the bit of nginx config you added to enable webroot authentication out of /var/www/letsencrypt we might be able to see what’s wrong with it. Or if you didn’t add any nginx configuration, you probably just want to use the public directory of your gitlab installation as your webroot instead.
I did use “root” in the config (attached) but since I’m trying to get the cert to work, I commented out this and gitlab (NGINX) is running using HTTP only now and when I ran the command that was unauthorized.
So not sure since it’s commented. When I tried to get the cert to work and changed my DNS from gitlab.ciwise.com to devops.ciwise.com, I do remove everything from /etc/letsencrypt but /var/www/letsencrypt/.well-known is still there and empty.
Should I run the cert creation with Gitlab shut down. I’m assuming that certbot automatically sets up a listener on HTTPS I thought, but I notice it’s HTTP (80) when it tries the acme site even using --staging.
I’m not sure how to do this because it’s Gitlab (A ruby on rails app using NGINX that’s part of the install package). I followed other how-to pages and the instructions were all similar. My issue is that even when I created a cert and configured, the connection after HTTP to HTTPS redirect occurred was forbidden.
This posting for help is because now I can’t seem to create the cert again.
LOL. I just added .well-known/acme-challenge and uncommented. It worked. The issue is that these how-tos on the web are written sometimes with no explanation of why. I realized that even though my Gitlab was running on port 80, this webroot needed to be in place when I run certbot.
Thanks for your help. Now, I have to get NGINX to host the certificate now. I think it may be permissions or owner issues. I’ll get it I’m sure.
2017/10/04 23:06:43 [emerg] 7118#0: BIO_new_file("/etc/letsencrypt/live/gitlab.ciwise.com/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen(’/etc/letsencrypt/live/gitlab.ciwise.com/fullchain.pem’,‘r’) error:2006D080:BIO routines:BIO_new_file:no such file)
Last entry. This was last night before I changed the DNS thinking I used all my certs for the week. So I guess it means nothing because I don’t know if NGINX is doing the HTTPS challenge. I only know that http url redirects to https. I also have flushed iptables and setup http and https ACCEPT. And, above the ss command says I’m listening on 443. I’m going to telnet devops.ciwise.com 443 now to check external.
