Hello
I’ve got several domains running on the same server, hence the same IPs
Three months ago, the renewal worked fine. But since about two weeks or so, any attempt to renew existing certificates produces connection timetout errors.
http-01 challenge for drumee.net
Using the webroot path /xxx/yyy for all unmatched domains.
Waiting for verification…
Failed authorization procedure. drumee.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://drumee.net/.well-known/acme-challenge/xx3BWabvNASGUahi6Cl1ejQShceLdcG2iGXqZxnpbK4: TimeoutIMPORTANT NOTES:
Domain: drumee.net
Type: connection
Detail: Fetching
TimeoutTo fix these errors, please make sure that your domain name was
By looking at the server log (nginx 1.6.2) there are no http request reaching the server
Trying a test file on the target link is OK with wget -S http://drumee.net/.well-known/test.txt
–2017-12-29 00:01:45-- http://drumee.net/.well-known/test.txt
Résolution de drumee.net (drumee.net)… 149.202.217.145, 2001:41d0:1000:1c91::2
Connexion vers drumee.net (drumee.net)|149.202.217.145|:80…connecté.
requête HTTP transmise, en attente de la réponse…
HTTP/1.1 200 OK
Server: nginx/1.6.2
Date: Thu, 28 Dec 2017 23:05:06 GMT
Content-Type: text/plain
Content-Length: 13
Last-Modified: Thu, 28 Dec 2017 22:03:33 GMT
ETag: "5a456a35-d"
Accept-Ranges: bytes
Longueur: 13 [text/plain]
Sauvegarde en : «test.txt.12»
Extract from log :
“type”: “http-01”,
“status”: “invalid”,
“error”: {
“type”: “urn:acme:error:connection”,
“detail”: “Fetching http://drumee.net/.well-known/acme-challenge/xx3BWabvNASGUahi6Cl1ejQShceLdcG2iGXqZxnpbK4: Timeout”,
“status”: 400**
“uri”: “https://acme-v01.api.letsencrypt.org/acme/challenge/8f-O5JwkTqfMi9B1bfwa7PusFrIsxSZH66SJy5ITIX4/2904510851”,
“token”: “xxxxxxxxxxxxxxxxxxxxxxxxxx”,**
“keyAuthorization”: “xxxxxxxxxxxxxxxxxxxx”,
“validationRecord”: [
“url”: “http://drumee.net/.well-known/acme-challenge/xx3BWabvNASGUahi6Cl1ejQShceLdcG2iGXqZxnpbK4”,
“hostname”: “drumee.net”,
“port”: “80”,
“addressesResolved”: [
“149.202.217.145”,
“2001:41d0:1000:1c91::2”
“addressUsed”: “2001:41d0:1000:1c91::2”,
“addressesTried”: []
