My domain is: starfirefarmga.com
I ran this command: certbot --nginx --redirect --webroot-path /etc/nginx/ -d starfirefarmga.com -d www.starfirefarmga.com
http-01 challenge for www.starfirefarmga.com
Waiting for verification…
Challenge failed for domain www.starfirefarmga.com
** - The following errors were reported by the server:**
** Domain: www.starfirefarmga.com**
** Type: unauthorized**
** Detail: Invalid response from**
** http://www.starfirefarmga.com/.well-known/acme-challenge/iixi6jTwVQ3QYn-Dy0-vcS6UPy8omy0wZ0ugald9k7o**
** : “\n\n\n\n<!–[if”**
** To fix these errors, please make sure that your domain name was**
** entered correctly and the DNS A/AAAA record(s) for that domain**
** contain(s) the right IP address.**
My web server is (include version): Centos
or certbot-auto --version
if you’re using Certbot):
certbot --version:- certbot 1.3.0
If I ping both the domains they are working fine and dns settings is also good and if I try to renew the certificate for both the domains it is not renewing properly
