i tried to search this but i didn’t get what i want so here is what i want to know.
After renewal of the certificate either automatically or manually do we need to reinstall that certificate, like if we copied those certificate in engine yard , so after renewal do we need to copy past renewed certificate ?
or is it like its just extend the validity of the certificate rather then changing the certificate it self.
If you’re using Certbot, you might benefit from the --deploy-hook feature, which tells Certbot to run a script after the certificate is renewed that can be used to copy the new certificate into another place.
