I am trying to to renew the certificate of www.maet.bg.
I have turned the server off.
I have cd to the path of the webroot folder and there I am executing:
maet_admin@maet:/var/www/html$
Do I have to turn https connections off when I try to renew to certificate?
I my nginx setup the location of ./well-known is accessible by all:
location ~ /.well-known {
allow all;
When I try to reach the url, it is going trough django and it is missing such a path so I get 404.
access_log /webapps/maet/logs/nginx-access.log;
error_log /webapps/maet/logs/nginx-error.log;
location /static/ {
alias /webapps/maet/website/static/;
location /media/ {
allow all;
root /var/www/html;
try_files $uri =404;
# an HTTP header important enough to have its own Wikipedia entry:
# http://en.wikipedia.org/wiki/X-Forwarded-For
# enable this if and only if you use HTTPS, this helps Rack
# set the proper protocol for doing redirects:
# proxy_set_header X-Forwarded-Proto https;
# pass the Host: header from the client right along so redirects
# can be set properly within the Rack application
proxy_set_header Host $http_host;
# we don't want nginx trying to do something clever with
# redirects, we set the Host: header above already.
proxy_redirect off;
# set "proxy_buffering off" *only* for Rainbows! when doing
# Comet/long-poll stuff. It's also safe to set if you're
# using only serving fast clients with Unicorn + nginx.
# Otherwise you _want_ nginx to buffer responses to slow
# clients, really.
# proxy_buffering off;
# Try to serve static files from nginx, no point in making an
# *application* server like Unicorn/Rainbows! serve static files.
if (!-f $request_filename) {
proxy_pass http://maet_app_server;
break;
# Error pages
error_page 500 502 503 504 /500.html;
location = /500.html {
root /webapps/maet/website/static/;
The webroot folder is the /var/www/html. I’ve created ./well-known/acme-challenge/test.html
Also I’ve created a /webapps/maet/.well-known/acme-challenge/test.html which is where django is serving the webpage.
This is how the certificate was added to the server:
Hi rg305 After trying to open the file for about two hours, I have managed to access it under the root of my Django project /webapps/maet/website/.well-known/
I was misusing root vs alias
However, now when I execute sudo certbot renew --dry-run
I am getting:
Processing /etc/letsencrypt/renewal/maet.bg.conf
http-01 challenge for maet.bg
http-01 challenge for www.maet.bg
Waiting for verification…
Unable to clean up challenge directory /var/www/html/.well-known/acme-challenge
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/maet.bg/fullchain.pem
/etc/letsencrypt/live/maet.bg/fullchain.pem (success)
I am guessing I might have a DNS problem since I can reach the test file with
curl -IkL4 http://www.maet.bg/.well-known/acme-challenge/test
returns HTTP/1.1 200 OK
Server: nginx/1.10.3 (Ubuntu)
Date: Mon, 30 Oct 2017 09:40:43 GMT
Content-Type: application/octet-stream
Content-Length: 0
Last-Modified: Mon, 30 Oct 2017 08:35:02 GMT
ETag: "59f6e436-0"
Accept-Ranges: bytes
The return is correct - there is no IPv6 address found in global DNS for www.maet.bg
And it is confirmed by your assertion.
However, that same can not be said about maet.bg:
Addresses: 2a03:b0c0:3:d0::24:8001
207.154.248.226
