My domain is: crunchygrooves.com
I ran this command: certbot certonly --pre-hook 'service apache24 stop' --post-hook 'service apache24 start' -d crunchygrooves.com --dry-run -v --standalone
FIRST RUN:
Running pre-hook command: service apache24 stop
Hook 'pre-hook' ran with output:
Stopping apache24.
Waiting for PIDS: 1841.
Simulating a certificate request for crunchygrooves.com
http-01 challenge for crunchygrooves.com
Running post-hook command: service apache24 start
Hook 'post-hook' ran with output:
Performing sanity check on apache24 configuration:
Starting apache24.
Hook 'post-hook' ran with error output:
Syntax OK
The dry run was successful.
SECOND RUN (SECONDS LATER):
Stopping apache24.
Waiting for PIDS: 1876.
Challenge failed for domain crunchygrooves.com
Domain: crunchygrooves.com
Type: connection
Detail: During secondary validation: 75.130.116.46: Fetching http://crunchygrooves.com/.well-known/acme-challenge/q8_8VT2oi7rJ-qRsCl8nDFOLUj7AUF_TkePYNLs5A7c: Timeout during connect (likely firewall problem)
Starting apache24.
Syntax OK
My web server is (include version): Apache 2.4.54
The operating system my web server runs on is (include version): FreeNAS 13
My hosting provider, if applicable, is: godaddy.com (DNS)
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): No (via godaddy.com)
or certbot-auto --version
if you're using Certbot): 1.27.0
