My domain is: binomialsoftware.com
certbot renew
Cert not yet due for renewal
No renewals were attempted
apache/2.4.48 (Debian)
Debian GN/Linux 11 (bullseye) dockered on Ubuntu 21.10
n/a
no
1.12.0
I have a site (binomialsoftware.com) that had a certificate about to run out so I ran certbot renew which seemed to run fine. Now the certificate for the www.binomialsoftware.com version has expired. binomialsoftware.com works. Running certbot renew now just gives me Cert not yet due for renewal.
It seems you've removed the www subdomain from your certificate on August 7th this year, if you look at your certificate history: crt.sh | binomialsoftware.com
Solution: re-add the www subdomain to your certificate.
I really have no idea how I did that it certainly wasn't on purpose. I probably spent 20-30 hours to create the first certificate trying different things. I guess you are saying I'm back to square one and have to create the certificate again ?
Usually, that would be the most straightforward solution indeed, as certbot does not have an easy method of adding/removing hostnames from an existing certificate. However, that requires knowledge of the original command used to get the certificate in the first place. Sometimes people don't know that command any longer.
It might also be possible to use the renew command in combination with adding new hostnames, but I'm not entirely sure. E.g. something like:
If that works, you can change --dry-run for --force-renewal and run the following command just once (because --force-renewal should only be used a single time if it succeeds!). --force-renewal is unfortunately required as otherwise certbot would claim the certificate is not yet due for renewal.. We know, certbot, we know! We just want to change it!
I tried the command above with --dry-run and the output was:
"Currently, the renew verb is capable of either renewing all installed certificates that are due to be renewed or renewing a single certificate specified by its name. If you would like to renew specific certificates by their domains, use the certonly command instead. The renew verb may provide other options for selecting certificates to renew in the future." So I didn't try without --dry-run
The content of the config file is:
I tried adding --cert-name also I have checked that I have an A record but I read somewhere that you also need a CNAME record which I didn't have so I created one
Now I got a message saying:
You are updating certificate binomialsoftware.com to include new domain(s):
You are also removing previously included domain(s):
(None)
Did you intend to make this change?
(U)pdate certificate/(C)ancel: U
Renewing an existing certificate for binomialsoftware.com and www.binomialsofware.com
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt
OK, you just need to wait an hour. Lets Encrypt will reject when you try too many times and fail. Ideally you use --dry-run or --test-cert but that can be awkward with --apache sometimes so best to wait.
As to CNAME, it is fine to have CNAME for the www.binomialsoftware.com pointing to the apex name. But, it also would have worked to make an A record for www.binomialsoftware.com - instead of a CNAME. Perhaps back in August you did have an A record for it but it got removed. Either way, CNAME or A, it should work in an hour.
[don't mind me - I'm just here to point out the obvious - LOL]
There is no planned long term support for U21 - just saying.
Also, you should check what certs are still managed, with: certbot certificates
and delete any that are no longer needed, with: certbot delete --cert-name {name of cert}
