I set up a subdomain a few months back to run Pleroma, a social media server. I managed to acquire a certificate using Let’s Encrypt. I don’t recall a problem at the time. I tried once to renew the certificate before it expired and came upon a problem, possibly relating to the certificate for the main domain at marginalie.eu. I must have set up redirects to https once I set up the certificate for the Pleroma virtual server. I am trying to understand the following error and currently suppose that it is due to the fact that certbot cannot access the website through http because of redirects. If this is correct, I presume I will have to reconfigure the sites-enabled file to permit http access before renewing.
If anybody can let me know if this is or is not in the right ball park, I will be grateful. Any additional pointers will be appreciated.
Many thanks
My domain is: ppp.marginalie.eu
[marginalie.eu has a valid certificate on a separate VS.]
Processing /etc/letsencrypt/renewal/ppp.marginalie.eu.conf
http-01 challenge for ppp.marginalie.eu
Attempting to renew cert from /etc/letsencrypt/renewal/ppp.marginalie.eu.conf produced an unexpected error: Failed authorization procedure. ppp.marginalie.eu (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://ppp.marginalie.eu/.well-known/acme-challenge/nJtV-is4wx5pzRFHAT7Oj_SpnepY5N2jN1FflduNcGk: Connection refused. Skipping.
/etc/letsencrypt/live/ppp.marginalie.eu/fullchain.pem (failure)
Domain: ppp.marginalie.eu
Type: connection
Detail: Fetching
Connection refused
My web server is (include version): nginx 1.10.3
The operating system my web server runs on is (include version): Debian 9.5 (Stretch)
My hosting provider, if applicable, is: Linode
