INTRODUCTION: I am using the renew command and am getting errors. Some of the error text pasted at end of this post I really don't understand because Certbot issued my now expired cert and didn't have a problem with readmyastrology.com then.. since I got my cert, since then, I have not changed a thing.. everything should be in place for it to renew.. I don't understand therefore why I am getting these errors. I am willing to pay someone who helps me resolve this as my sites 5 of them on one cert, are down now and I'm losing business. I can be reached on das@goravani.com
My domain is: Goravani.com
I ran this command: sudo certbot renew
It produced this output: See pasted text at end of these questions
My web server is (include version): Apache 2
The operating system my web server runs on is (include version): Macintosh Catalina
My hosting provider, if applicable, is: Myself of a Macintosh
I can login to a root shell on my machine (yes or no, or I don't know): SUDO does that right?
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): MAMP PRO LATEST VERSION
or certbot-auto --version
if you're using Certbot): I'M USING Terminal of course, from Catalina.. release version
ERROR TEXT
Processing /etc/letsencrypt/renewal/goravani.com.conf
http-01 challenge for www.readmyastrology.com
Using the webroot path /Applications/MAMP/htdocs/dasgoravani for all unmatched domains.
Challenge failed for domain www.readmyastrology.com
Attempting to renew cert (goravani.com) from /etc/letsencrypt/renewal/goravani.com.conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/goravani.com/fullchain.pem (failure)
Additionally, the following renewal configurations were invalid:
/etc/letsencrypt/renewal/jyotishstudio.com.conf (parsefail)
1 renew failure(s), 1 parse failure(s)
Domain: www.readmyastrology.com
Detail: Invalid response from
http://www.readmyastrology.com/.well-known/acme-challenge/7RSgsRqAHdbGDQGyQx_65-U09uqnuCt58lRHL2wQeEY
[50.53.69.117]: "\n\n404 Not
Found\n\nNot Found
\n<p"To fix these errors, please make sure that your domain name was
