My domain is: eenfach.de
java -jar acme_client.jar --command verify-domains -a /etc/pjac/account.key -w /etc/pjac/workdir/ -c /etc/pjac/eenfach.de.csr --challenge-type DNS01
Exception in thread “main” org.shredzone.acme4j.exception.AcmeLazyLoadingException: Order https://acme-v02.api.letsencrypt.org/acme/order/67299589/1157210309
at org.shredzone.acme4j.AcmeJsonResource.getJSON(AcmeJsonResource.java:68)
at org.shredzone.acme4j.Order.getAuthorizations(Order.java:107)
at com.jblur.acme_client.command.certificate.VerifyDomainsCommand.commandExecution(VerifyDomainsCommand.java:51)
at com.jblur.acme_client.command.ACMECommand.execute(ACMECommand.java:47)
at com.jblur.acme_client.CommandExecutor.executeACMECommand(CommandExecutor.java:123)
at com.jblur.acme_client.CommandExecutor.execute(CommandExecutor.java:74)
at com.jblur.acme_client.Application.main(Application.java:65)
Caused by: org.shredzone.acme4j.exception.AcmeServerException: No order for ID 1157210309
at org.shredzone.acme4j.connector.DefaultConnection.throwAcmeException(DefaultConnection.java:490)
at org.shredzone.acme4j.connector.DefaultConnection.performRequest(DefaultConnection.java:417)
at org.shredzone.acme4j.connector.DefaultConnection.sendSignedRequest(DefaultConnection.java:346)
at org.shredzone.acme4j.connector.DefaultConnection.sendSignedPostAsGetRequest(DefaultConnection.java:147)
at org.shredzone.acme4j.AcmeJsonResource.update(AcmeJsonResource.java:119)
at org.shredzone.acme4j.AcmeJsonResource.getJSON(AcmeJsonResource.java:63)
… 6 more
Apache/2.4.41 (Unix) OpenSSL/1.1.1d
Solaris 11.3/sparc
no
or certbot-auto --version
if you’re using Certbot):
(1656) toy:/root/acme# java -jar acme_client.jar --version
Porunov Java ACME Client (PJAC) v3.0.1
