azabot.stream
sudo certbot --nginx
1: azabot.stream
2: unifi.azabot.stream
Attempting to parse the version 1.9.0 renewal configuration file found at /etc/letsencrypt/renewal/azabot.stream.conf with version 0.40.0 of Certbot. This might not work.
Attempting to parse the version 1.11.0 renewal configuration file found at /etc/letsencrypt/renewal/unifi.azabot.stream.conf with version 0.40.0 of Certbot. This might not work.
http-01 challenge for azabot.stream
nginx: [warn] conflicting server name "azabot.stream" on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name "azabot.stream" on [::]:80, ignored
Challenge failed for domain azabot.stream
Domain: azabot.stream
Detail: Invalid response from
http://azabot.stream/.well-known/acme-challenge
nginx version: nginx/1.18.0 (Ubuntu)
Ubuntu 20.04.1
BuyVM
Yes
No
or certbot-auto --version
if you're using Certbot):
certbot 0.40.0
I am guessing that this is an issue of me not having my nginx config setup correctly and it not being able to access the challenge that it is creating. To that end here is the default sites config that I have. (I am still learning Nginx so I am sure this is ugly and there are things I can do better, feel free to help me learn)
listen 80 default_server;
root /var/www/html;
index index.php index.html index.htm index.nginx-debian.html;
server_name azabot.stream;
try_files $uri $uri/ =404;
location ~ \.php$ {
include snippets/fastcgi-php.conf;
fastcgi_pass unix:/run/php/php7.4-fpm.sock;
location ~ /\.ht {
deny all;
root /var/www/html;
server_name azabot.stream; # managed by Certbot
location /twitch/eventsub/callback {
proxy_set_header Host $host;
proxy_set_header Connection "Upgrade";
proxy_http_version 1.1;
proxy_pass https://azabot.stream:8054/twitch/eventsub/callback;
location /azabot {
proxy_pass https://azabot.stream:8054;
ssl_certificate /etc/letsencrypt/live/azabot.stream/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/azabot.stream/privkey.pem; # managed by Certbot
if ($host = azabot.stream) {
} # managed by Certbot
listen 80 ;
listen [::]:80 ;
