I am using LE for a Nextcloud installation on my NAS at home. As dynamic DNS Service I am using zzzz.io. After setting up my nextcloud I obtained a LE cert. Now it is due to renewal, so I ran letsencrypt renew on my machine. Unfortunately my renewal fails due to an error I don’t understand:
Domain: MYSUBDOMAIN.zzzz.io
Detail: Incorrect validation certificate for tls-sni-01 challenge.
Requested
f690ef0…237be42.acme.invalid
from MYISPIP:443. Received 2 certificate(s), first
certificate had names “MYSUBDOMAIN.zzzz.io”
The DNS record for the domain contains the correct IP (MYISPIP) and the certificate should indeed have the name MYSUBDOMAIN.zzzz.io in it or am I wrong? It might be a problem that I also have nginx running (for the NAS admin panel) but I have the same error when stopping nginx.
The DNS probably isn’t the issue here, but we can’t tell since you obfuscated your domain name. You’re still using the tls-sni-01 challenge type, which was deprecated for security concerns but is still available for renewals of existing certificates. It will eventually be fully disabled, though, so you should consider re-configuring your system to use http-01 or dns-01 instead at some point.
However, for the immediacy, the way tls-sni-01 works is by attempting to configure your web server to serve a specific fake certificate in response to a specific SNI request. For the challenge, it should be seeing an _acme-invalid certificate, but rather is seeing your real certificate. If something else is terminating SSL before it gets to your server, that could cause this issue.
Honestly, though, if I were you I’d get ahead of things and start transitioning your server to use http-01 instead. Since you didn’t answer the questions, I don’t really have any more info on exactly how to go about that.
