Renew does not work on Debian Trixie
My domain are: performance.izzop.com, consult.izzop.com, galerie.izzop.com ....
certbot --standalone rewen
It produced this output: Output too long .... (170 Ko) I extract the end :
2025-01-13 15:42:45,244:DEBUG:acme.client:Storing nonce: 5VsalEMJ3arn6L9D-sFP1SWDWQJyzWRJkuGIY-FqznoY9qUDFz0
2025-01-13 15:42:45,245:INFO:certbot._internal.auth_handler:Challenge failed for domain performance6.jppozzi.dyndns.org
2025-01-13 15:42:45,245:INFO:certbot._internal.auth_handler:http-01 challenge for performance6.jppozzi.dyndns.org
2025-01-13 15:42:45,245:DEBUG:certbot._internal.display.obj:Notifying user:
  Domain: performance6.jppozzi.dyndns.org
  Type:   unauthorized
  Detail: 176.187.84.182: Invalid response from https://performance6.jppozzi.dyndns.org/.well-known/acme-challenge/6iKOg35diTyM8rvagvtu3dzO_i1gu75DvMF75dMoC50: 404
2025-01-13 15:42:45,245:DEBUG:certbot._internal.error_handler:Encountered exception:
  File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 108, in handle_authorizations
    self._poll_authorizations(authzrs, max_retries, max_time_mins, best_effort)
  File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 212, in _poll_authorizations
2025-01-13 15:42:45,245:DEBUG:certbot._internal.error_handler:Calling registered functions
2025-01-13 15:42:45,245:INFO:certbot._internal.auth_handler:Cleaning up challenges
2025-01-13 15:42:45,245:DEBUG:certbot._internal.plugins.standalone:Stopping server at :::80...
2025-01-13 15:42:45,462:ERROR:certbot._internal.renewal:Failed to renew certificate performance6.jppozzi.dyndns.org with error: Some challenges have failed.
2025-01-13 15:42:45,462:DEBUG:certbot._internal.renewal:Traceback was:
  File "/usr/lib/python3/dist-packages/certbot/_internal/renewal.py", line 540, in handle_renewal_request
    main.renew_cert(lineage_config, plugins, renewal_candidate)
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1550, in renew_cert
    renewed_lineage = _get_and_save_cert(le_client, config, lineage=lineage)
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 131, in _get_and_save_cert
    renewal.renew_cert(config, domains, le_client, lineage)
  File "/usr/lib/python3/dist-packages/certbot/_internal/renewal.py", line 399, in renew_cert
    new_cert, new_chain, new_key, _ = le_client.obtain_certificate(domains, new_key)
  File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 428, in obtain_certificate
  File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 496, in _get_order_and_authorizations
2025-01-13 15:42:45,463:DEBUG:certbot._internal.display.obj:Notifying user:
2025-01-13 15:42:45,463:ERROR:certbot._internal.renewal:All renewals failed. The following certificates could not be renewed:
2025-01-13 15:42:45,463:ERROR:certbot._internal.renewal:  /etc/letsencrypt/live/consult.izzop.com/fullchain.pem (failure)
  /etc/letsencrypt/live/consult.jppozzi.dyndns.org/fullchain.pem (failure)
  /etc/letsencrypt/live/galerie.izzop.com/fullchain.pem (failure)
  /etc/letsencrypt/live/galerie.jppozzi.dyndns.org/fullchain.pem (failure)
  /etc/letsencrypt/live/jppozzi.dyndns.org/fullchain.pem (failure)
  /etc/letsencrypt/live/performance.izzop.com/fullchain.pem (failure)
  /etc/letsencrypt/live/performance.jppozzi.dyndns.org/fullchain.pem (failure)
  /etc/letsencrypt/live/performance6.izzop.com/fullchain.pem (failure)
  /etc/letsencrypt/live/performance6.jppozzi.dyndns.org/fullchain.pem (failure)
2025-01-13 15:42:45,463:DEBUG:certbot._internal.display.obj:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2025-01-13 15:42:45,463:DEBUG:certbot._internal.log:Exiting abnormally:
  File "/usr/bin/certbot", line 33, in <module>
    sys.exit(load_entry_point('certbot==2.11.0', 'console_scripts', 'certbot')())
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 19, in main
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1894, in main
  File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1642, in renew
    renewed_domains, failed_domains = renewal.handle_renewal_request(config)
  File "/usr/lib/python3/dist-packages/certbot/_internal/renewal.py", line 568, in handle_renewal_request
    raise errors.Error(
certbot.errors.Error: 9 renew failure(s), 0 parse failure(s)
2025-01-13 15:42:45,463:ERROR:certbot._internal.log:9 renew failure(s), 0 parse failure(s)
My web server is (include version): --standalone
The operating system my web server runs on is (include version): Debian Trixie
My hosting provider, if applicable, is: self hosted in a VM
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): none
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.11.0
Regards
JP P
The --standalone option requires exclusive use of port 80. Did you stop your Apache server before running that?
I say Apache because that is what is replying to HTTP requests right now.
Have you considered using the --webroot or --apache option instead of --standalone now that you have Apache running?
Hello,
Apache and haproxy were not running and thé port 80 was free. It is not the first time I renew my certs, but it is the first time with Debian Trixie.
I have followed the process I use since some years.
It could be a problem with Trixie.
Regards
JP P
I doubt it. The error was a '404' which means something replied to the Let's Encrypt server with that. The --standalone option would never reply with that code. There is likely something else running on that port then.
What does this show before you try running --standalone?
sudo ss -pant | grep -i listen | grep ':80' | grep -v grep
And, would you show the Certbot command again? It got lost in your original post
Did you upgrade your o/s in place? Or is it a new virtual server? If the latter does your DNS still point to the right IP?
Hello,
I ran the command :
LISTEN 0 4096 192.168.2.80:80 0.0.0.0:* users:(("haproxy",pid=130192,fd=10))
Only "haproxy" uses the port 80 but I stop it before launching the certbot command :
certbot --standalone renew
Hope this is OK for you.
Regards
JP P
I asked to see the output of the ss command just before you ran Certbot.
That is an unusual way to run the renew command. What does this show
sudo certbot certificates
Hello,
The result of : "certbot certificates" is rather long, here truncated after the first cert listed ;
Then what is output of:
sudo certbot certificates --cert-name performance6.jppozzi.dyndns.org
Hello,
Output is:
/usr/lib/python3/dist-packages/certbot/ocsp.py:238: CryptographyDeprecationWarning: Properties that return a naïve datetime object have been deprecated. Please switch to this_update_utc.
if not response_ocsp.this_update:
/usr/lib/python3/dist-packages/certbot/ocsp.py:240: CryptographyDeprecationWarning: Properties that return a naïve datetime object have been deprecated. Please switch to this_update_utc.
if response_ocsp.this_update > now + timedelta(minutes=5):
/usr/lib/python3/dist-packages/certbot/ocsp.py:242: CryptographyDeprecationWarning: Properties that return a naïve datetime object have been deprecated. Please switch to next_update_utc.
if response_ocsp.next_update and response_ocsp.next_update < now - timedelta(minutes=5):
Regards
JP P
Found the following matching certs:
Certificate Name: performance6.jppozzi.dyndns.org
Serial Number: 43e14c6cb04b9c5b4a9f6a809f2de9696bf
Key Type: RSA
Domains: performance6.jppozzi.dyndns.org
Expiry Date: 2025-01-29 15:02:58+00:00 (VALID: 14 days)
Certificate Path: /etc/letsencrypt/live/performance6.jppozzi.dyndns.org/fullchain.pem
Private Key Path: /etc/letsencrypt/live/performance6.jppozzi.dyndns.org/privkey.pem
Now please show contents of the renewal config profile:
/etc/letsencrypt/renewal/performance6.jppozzi.dyndns.org.conf
Hello,
cat /etc/letsencrypt/renewal/performance6.jppozzi.dyndns.org.conf
version = 2.1.0
archive_dir = /etc/letsencrypt/archive/performance6.jppozzi.dyndns.org
cert = /etc/letsencrypt/live/performance6.jppozzi.dyndns.org/cert.pem
privkey = /etc/letsencrypt/live/performance6.jppozzi.dyndns.org/privkey.pem
chain = /etc/letsencrypt/live/performance6.jppozzi.dyndns.org/chain.pem
fullchain = /etc/letsencrypt/live/performance6.jppozzi.dyndns.org/fullchain.pem
[renewalparams]
account = 6b86e312c316ab1b30e13b12f9f96fad
authenticator = standalone
key_type = rsa
Regards
JP P
PS : I go to bed, it is 23:51 here
Returning tomorrow morning ...
Okay, let's walk through this carefully to identify the root cause.
We'll just work on the performance subdomain and likely same issue for all.
Your Certbot renewal for that confirms --standalone. So, lets test that:
  1. Stop haproxy as it uses port 80
  2. Show output of this:
Need to make certain port 80 is available. Maybe haproxy stop works different now. Or perhaps some monitoring system notices it is stopped and restarts it. If nothing shows for port 80 go to next step. Otherwise we have found the reason :slight_smile:
  1. Show output of this (will not affect existing production certs)
sudo certbot renew --dry-run --cert-name performance6.jppozzi.dyndns.org
  1. If that fails for any reason, upload:
/var/log/letsencrypt/letsencrypt.log
You will need to copy it to a .txt file to upload to this forum
Hello,
return nothing
Processing /etc/letsencrypt/renewal/performance6.jppozzi.dyndns.org.conf
Account registered.
Simulating renewal of an existing certificate for performance6.jppozzi.dyndns.org
Congratulations, all simulated renewals succeeded:
/etc/letsencrypt/live/performance6.jppozzi.dyndns.org/fullchain.pem (success)
As I have an update on the internet bridge/firewall system I hope it was it the culprit before than upgrade ... from Bookworm to Trixie.
Will try the complete renewal, and it works, I will try to understand why the firewall has done weird things ...
Regards ans thanks for your kindness.
JP P
