My domain is: Sourcesinfo.com
I ran this command: certbot renew and also certbot renew --pre-hook “service apache24 stop” --post-hook “service apache24 start”
certbot renew --pre-hook “service apache24 stop” --post-hook "service apache24 start"
Processing /usr/local/etc/letsencrypt/renewal/sourcesinfo.com.conf
Running pre-hook command: service apache24 stop
Output from service:
Stopping apache24.
Waiting for PIDS: 2026.
http-01 challenge for sourcesinfo.com
http-01 challenge for ecurealestate.com
http-01 challenge for genesyscare.com
http-01 challenge for uxsources.com
Waiting for verification…
Attempting to renew cert (sourcesinfo.com) from /usr/local/etc/letsencrypt/renewal/sourcesinfo.com.conf produced an unexpected error: Failed authorization procedure. uxsources.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://uxsources.com/.well-known/acme-challenge/PaT_htu3uXuZq_Cg24oGWo8myLhYSkFsqyIHEU0av08: Connection refused, genesyscare.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://genesyscare.com/.well-known/acme-challenge/JJY9MUrI4SI5xpFJ_3t9mEu2i5UyolIpv7fqqfAKg2o: Connection refused, ecurealestate.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://ecurealestate.com/.well-known/acme-challenge/0Om_CaOI2O1xnzB7GxaggwGsxEy3rmzuPuvVF_t1Axs: Connection refused, sourcesinfo.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://sourcesinfo.com/.well-known/acme-challenge/bMLrZcEW3Y6_DQMddA30WGY8k0sudsR5NFDVeiQq6IU: Connection refused. Skipping.
/usr/local/etc/letsencrypt/live/sourcesinfo.com/fullchain.pem (failure)
Running post-hook command: service apache24 start
Performing sanity check on apache24 configuration:
Starting apache24.
Error output from service:
Syntax OK
Stopping apache24.
Starting apache24.
Syntax OK
My web server is (include version):apache24
The operating system my web server runs on is (include version):freebsd-11.1- -RELEASE-p4
My hosting provider, if applicable, is: self hosting
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
