My domain is:https://juwelier-goeschl.at
I ran this command: certbot certonly --manual
It produced this output: NET::ERR_CERT_COMMON_NAME_INVALID
The operating system my web server runs on is (include version): Linux
My hosting provider, if applicable, is: A1
I can login to a root shell on my machine (yes or no, or I don't know): no
or certbot-auto --version
if you're using Certbot): 1.16.0
Hello Community!
First of all - I have to admit that I am not a professional. I have designed the company website via wordpress and came to the issue of no SLL certificate, so I tried to implement one 3 months ago, which - with the help of a relative - I got to work, with www.juwelier-goeschl.at and juwelier-goeschl.at
Now that I wanted to renew it, I've experienced an issue, and I can't figure out, why I could renew www.juwelier-goeschl.at, but not juwelier-goeschl.at
What I've done to renew was:
C:\WINDOWS\system32>certbot certonly --manual
Saving debug log to C:\Certbot\log\letsencrypt.log
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): www.juwelier-goeschl.at
Renewing an existing certificate for www.juwelier-goeschl.at
Create a file containing just this data:
9bb2w9Euj6dUkvBCWAhqr1y3QL_kz-NySi1u1xyXVaw.v7bB3Jj5fdM-Q3e4g9a6C6sOpHVqoA93_d4GTypVEAI
Press Enter to Continue
Certificate is saved at: C:\Certbot\live\www.juwelier-goeschl.at\fullchain.pem
Key is saved at: C:\Certbot\live\www.juwelier-goeschl.at\privkey.pem
This certificate expires on 2021-11-30.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
I know that I forgot that I had to do it for both domains at once, so I tried to correct my mistake, but I always got this:
space separated) (Enter 'c' to cancel): www.juwelier-goeschl.at, juwelier-goeschl.at
requested (ref: C:\Certbot\renewal\www.juwelier-goeschl.at.conf)
It contains these names: www.juwelier-goeschl.at
You requested these names for the new certificate: www.juwelier-goeschl.at,
certificate?
(E)xpand/(C)ancel: e
Renewing an existing certificate for www.juwelier-goeschl.at and juwelier-goeschl.at
tllDKEHyiufJKLVM43Oepw104_liPr-zkH1Foifw6Yk.v7bB3Jj5fdM-Q3e4g9a6C6sOpHVqoA93_d4GTypVEAI
http://juwelier-goeschl.at/.well-known/acme-challenge/tllDKEHyiufJKLVM43Oepw104_liPr-zkH1Foifw6Yk
Domain: juwelier-goeschl.at
Type: connection
Detail: During secondary validation: Fetching http://juwelier-goeschl.at/.well-known/acme-challenge/tllDKEHyiufJKLVM43Oepw104_liPr-zkH1Foifw6Yk: Timeout during connect (likely firewall problem)
Hint: The Certificate Authority failed to verify the manually created challenge files. Ensure that you created these in the correct location.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
What did I do wrong?
Thanks for your help!
