I realize it is pro forma, but don’t see the need, all I want to do is force a new cert to be generated prior to the default 30 day remaining restriction. Normally, when the certs are ready to expire and the script completes, for a given domain, I cut and paste the contents of the generated files to my sites via the hosts control panel, which then restarts, I presume, the web server for that domain. Works fine. But in this case the cert is not due to expire, so I get the error shown and no new files.
Great! I'm glad to hear you found the solution you need. Thanks for reporting back so the next person using getssl with the same question can jump to the solution
