Renew certificat - how to do help me
Hello,
I would like to know how to renew an expired certificate since 1 week but I really don’t know how to do… actually I’ve got a website server on KimSufi with a domaine name / subdomain on Gandi.
I order this secure website https://dispatcher.shantitravel.com last year and I’m not in touch anymore with my developer but I have access to everything. Can you help me to solve this please ?
Thanks,
Jonathan
Hi @shantitravel
it’s really helpful if you are able to answer the following questions.
There is an older check of your main domain - https://check-your-website.server-daten.de/?q=shantitravel.com
There are some errors.
Your subdomain looks ok - https://check-your-website.server-daten.de/?q=dispatcher.shantitravel.com
http://dispatcher.shantitravel.com/
37.187.125.238 301 https://dispatcher.shantitravel.com/ 0.053 A
37.187.125.238 401 0.840 N
Unauthorized
Certificate error: RemoteCertificateChainErrors
http://dispatcher.shantitravel.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
37.187.125.238 301 https://dispatcher.shantitravel.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.053 A
Visible Content: Moved Permanently The document has moved here . Apache/2.4.25 (Debian) Server at dispatcher.shantitravel.com Port 80
https://dispatcher.shantitravel.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 401 0.290 N
Unauthorized
Visible Content:
is ok.
But the questions - control panel yes/no, root access, possible client - are important.
