New to this role so any help gratefully appreciated.
Licence expired today but thought we had a scheduled task to renew licences. Doesn’t seem to be outputting licence anywhere for me to pick up. How do i go about renewing a licence?
Hi @khillman , I think you mean “certificate”, not “licence”.
Thanks
My domain is: oakwood.surrey.sch.uk
I ran this command: a scheduled task to check for renewals:
E:\win-acme.v1.9.11.2\letsencrypt.exe with arguments --renew --baseuri “https://acme-v01.api.letsencrypt.org/”
It produced this output: Nothing seems to happen?
My web server is (include version): IIS 8
The operating system my web server runs on is (include version): Server 2012 R2
I can login to a root shell on my machine (yes or no, or I don’t know): I Don’t know
Can you try E:\win-acme.v1.9.11.2\letsencrypt.exe --verbose --renew --baseuri https://acme-v01.api.letsencrypt.org/
Maybe you can try to update to win-acme.v1.9.11.3 ?
That seemed to do something, where will it have put the certificate?
the certificate is requested and saved to a (Central) Certificate Store using a store plugin. If you're not sure what do to with this information, the defaults should be fine.
OK, sorry for the simple questions but how do i then go about importing this into IIS?
Hi @khillman
if the certificate is stored in your Machine.Webhosting - Certificatestore, you can update your https - binding.
Check the bindings - dialog of your website.
