Regarding SSL Certificate Issue for .NET Domain
Dear Let's Encrypt Team,
I am writing to formally raise a complaint regarding the inability to obtain an SSL certificate for my domain, elevated-marketing.net. Despite multiple attempts to install SSL using Let’s Encrypt, the authentication process fails, citing an "unauthorized response" and a failure to verify the ACME challenge.
Issue Details:
Troubleshooting Steps Taken:
  1. Verified DNS records and confirmed that the domain points to the server correctly.
  2. Checked and configured Nginx to serve ACME challenge files correctly.
  3. Ensured firewall settings allow traffic on ports 80 and 443.
  4. Attempted both the --nginx and --webroot methods for SSL installation.
  5. Confirmed file permissions and web server accessibility.
Despite these measures, the SSL verification process continues to fail. I kindly request your technical team to investigate whether there are any restrictions, DNS misconfigurations, or server-level limitations that may prevent SSL installation on my .NET domain.
I appreciate your prompt assistance in resolving this matter, as SSL is critical for securing my website and ensuring user trust. Please provide any necessary guidance or action steps required from my end.
Looking forward to your swift response.
Best Regards,
Daoud Hussain
daoudhussaindevops@gmail.com
Welcome to the Let's Encrypt Community! :slightly_smiling_face:
Also, the installed certificate is for a different domain name:
This is the Let's Encrypt Community, mostly used by volunteers like myself, not an official way of reaching out to the Let's Encrypt staff.
You might get better results in the Help section asking volunteers to help you with your situation instead of raising complaints :slight_smile: As the snippet of info from the error message you have provided does not show any evidence of "restrictions, DNS misconfigurations, or server-level limitations" on Let's Encrypts side. It suggests incorrect configuration on the users end.
Futher more, I agree with what @griffin found: your server seems to be sending your website nicely to browsers over IPv4 using nginx, but over IPv6 it just responds with 404 file not found errors, served by the Google ghs webserver. And Let's Encrypt prefers IPv6 over IPv4, resulting in the error.
Please first fix your webserver so it works when IPv6 is prefered (either by fixing IPv6 or disabling it entirely, including removing the AAAA RRs in DNS) and try again.
Also, but that's personal:
Why this? Let's Encrypt issues more than 5 million certs daily and has a very small team to do so. And it's free of charge. Why this "complaint" with all the hasty notions? Let's Encrypt doesn't owe you anything. You're lucky we volunteers aren't that petty in that we wouldn't provide you with the solution to your problem despite the negative way you posted this thread.
Hello @Daoud-Hussain,
Had you opened this thread in the Help section, you would have been provided with a questionnaire. All the answers to this questionnaire are required:
Thank you for assisting us in helping YOU!
