Hi all,
i am using a virtual host to point a domain to a specific folder after installing letencrypt I am facing an issue with redirection. I am using prestashop for this website
this host configuration file : lpfiles.com.conf
<VirtualHost *:80>
# specifies what hostname must appear in the request’s Host: header to
#ServerName www.example.com
ServerAdmin admin@hyderabadbazar.com
ServerName hyderabadbazar.com
ServerAlias www.hyderabadbazar.com
DocumentRoot /var/www/html/lpfiles
<Directory /var/www/html/lpfiles>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =hyderabadbazar.com [OR]
RewriteCond %{SERVER_NAME} =www.hyderabadbazar.com
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
but if i remove
my site is working fine but https is appearing.
can some one please help me out
