Recreate SSL Certificate after Server re built
Yes i used sucuri.
I think the main issue is the missing SSL certificates from the server itself.
Can i completely remove the SSL from the website and then issue a new one from Let’s Encrypt?
I don't understand the problem.
The picture doesn't show a certificate problem.
I would think so.
You should be able to undo and then redo the whole SSL cert process.
But that may depend on where/how the cert was provided/obtained.
If by Sucuri, then through their control panel?
If by LE, then by whatever ACME client you used.
Also:
The site is still geo-location blocking (http & https)
This will create problems obtaining and renewing certs.
I used Let’ Encrypt to to create the SSL Certificate back in December. Everything was working fine.
But the server that was having the certificates after the configuration was rebuilt again, which blew all the certificates that where saved in the server. Thus making it difficult for the server to connect again via https.
Right now, the website is showing that it is not secured. But when i test the domain, deeds.gamregistry.com on sslLab, it says that the certificate is still valid. But the problem is, the website is no more using the certificate.
Thats why we had this issue earlier on:
- Your hosting server is forcing the use of plain HTTP, but your SSL Mode setting is set to ‘Full HTTPS’. You should change that to ‘Partial HTTPS’.
OK so using partial HTTPS didn't get it working?
Where do you see this?
[I get geo-location blocked - so I see nothing at all]
On the website itself.
here it is:
Can you click the lock and show the cert?
In the Connection section what shows when you click the >
Does the URL start with https ?
No, it doesnt have any https
All sites that start with http will have that message.
Add https and what does that say?
This is what i get after testing it with ssllab
So where is the problem?
The problem is, the domain is trying to communicate with the certificate files in the server during the first configuration.
But those files are unintentionally deleted from the server. Hence causing the problem
Please show the problem.
I don't see it.
SSLLabs doesn't see it.
It seems, only you see it.
But you can't show it, nor explain it enough, to get it resolved.
