Reason for Error ""DNS problem: SERVFAIL looking up A for ir.vasco.com"
My domain is: ir.vasco.com
dig -q CAA vasco.com
Query results for CAA vasco.com
Response:
;; opcode: QUERY, status: NOERROR, id: 13029
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;; QUESTION SECTION:
;vasco.com. IN CAA
;; AUTHORITY SECTION:
vasco.com. 0 IN SOA ns1.p28.dynect.net. hostmaster.vasco.com. 2011116209 3600 600 604800 1800
I can login to a root shell on my machine (yes or no, or I don’t know):No
According to dnsviz, it looks like you have some DNSSEC errors: http://dnsviz.net/d/ir.vasco.com/dnssec/
Thank you for your response. Is there a way to fix it without removing DNSSEC for the domain?
Most likely there is, but I’m afraid I don’t know what steps you would need to take. Removing DNSSEC would be the simplest option.
If we create a new zone for ir.vasco.com and disable DNSSEC on it. Does the validation still check for DNSSEC records going from .com to vasco.com? I believe if that is the case, the validation would still fail?
Yes, that is correct.
Your DS record is incorrect. You need to obtain the correct one from the Dyn control panel and correct it in the domain registration control panel.
