Yes, please delete it now.
We can get you another one whenever you are ready for it.
but have
# apachectl -t
apache2: Syntax error on line 225 of /etc/apache2/apache2.conf: Syntax error on line 16 of /etc/apache2/sites-enabled/jirafeau-ssl.c
onf: Could not open configuration file /etc/letsencrypt/options-ssl-apache.conf: No such file or directory
Action '-t' failed.
and if I comment the include I have that :
# apachectl -t
AH00526: Syntax error on line 18 of /etc/apache2/sites-enabled/jirafeau-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/jirafeau.tbbt.xenbox.fr/fullchain.pem' does not exist or is empty
Action '-t' failed.
fabulous!
Here it is:
# this file.
SSLEngine on
# Intermediate configuration, tweak to your needs
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
SSLHonorCipherOrder on
SSLCompression off
SSLOptions +StrictRequire
# Add vhost name to log entries:
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-agent}i\"" vhost_combined
LogFormat "%v %h %l %u %t \"%r\" %>s %b" vhost_common
#CustomLog /var/log/apache2/access.log vhost_combined
#LogLevel warn
#ErrorLog /var/log/apache2/error.log
# Always ensure Cookies have "Secure" set (JAH 2012/1)
#Header edit Set-Cookie (?i)^(.*)(;\s*secure)??((\s*;)?(.*)) "$1; Secure$3$4"
Feel free to make changes to it if you like.
Note: If you do modify it, certbot
updates might ignore it (not update it - in the future).
Then to get you that cert:
certbot certonly --webroot -w /var/www/Jirafeau/ -d jirafeau.tbbt.xenbox.fr
Then:
certbot certificates
[to confirm the cert-name]
I'm sorry this has taken so long.
But I really need to go now.
You should be able to finish easily - if not, post here and someone (else) will respond soon.
thanks
