My domain is: www.multidiversions.com
I ran this command:certbot certonly -d www.multidiversions.com --standalone
My web server is (include version):Wildcat V8.0.454.12 X64
The operating system my web server runs on is (include version): Win 10 Pro
My hosting provider, if applicable, is:Google
I can login to a root shell on my machine (yes or no, or I don't know): no
New cert was successfully created but after install & re-start, I get this error in the SSL startup log:
20211102 13:32:53 (HTTP) ssl_context_init: 0B080074 use_RSAPrivateKey_file error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
20211102 13:32:53 SSLContext::InitContext Context Initialization Failed.
Reinstall old Cert, and everything is OK!
