MNote
April 24, 2019, 3:44pm
1
We are about to launch small server computer to the consumer market with a computer manufacture.
Nextcloud is an open source, self-hosted file share and communication platform. Access & sync your files, contacts, calendars & communicate and collaborate across your devices. You decide what happens with your data, where it is and who can...
Every server has a hostname like
abc.wafflecell.com
xyz.wafflecell.com
Since we expect to have quite many customers, we have applied for the rate limit adjustment. Is it hard to get this kind of application accepted? And does it take long to get the result?
Thank you in advance.
Hi @MNote
there is another option.
If it is possible, add wafflecell.com
to the Public Suffix List:
https://publicsuffix.org/
Then the full qualified domain names abc.wafflecell.com
are domains, not subdomains.
They would be isolated (cookies) and the rate limit would be per domain, so there is no problem with any rate limit.
It's like a domain
example.co.uk
MNote
April 25, 2019, 3:34am
4
Thank you for your advice, Juergen.
Yes, we have just submitted the request to include wafflecell.com to the public suffix list. However, it would take three to four months to get on the list.
Best regards
schoen
April 25, 2019, 3:38am
5
The Letβs Encrypt rate limit adjustment process usually takes a few weeks.
MNote
April 25, 2019, 5:15am
6
Thank you, schoen. I will wait.
system
Closed
May 25, 2019, 5:15am
7
