Questions re: OpenSSL Client Compatibility Changes for Let’s Encrypt Certificates
I just ran a few tests with a Debian Stretch test VM, default settings.
# cat /etc/os-release
PRETTY_NAME = "Debian GNU/Linux 9 (stretch)"
# wget https://letsencrypt.org/certs/staging/letsencrypt-stg-root-x1.pem
# wget https://letsencrypt.org/certs/staging/letsencrypt-stg-root-dst.pem
# cat letsencrypt-stg-root-dst.pem letsencrypt-stg-root-x1.pem > certs-combined.pem
# openssl version
OpenSSL 1.1.0l 10 Sep 2019
Simulating that only ISRG Root X1 is in the trust store:
# openssl s_client -connect expired-root-ca-test.germancoding.com:443 -servername expired-root-ca-test.germancoding.com -verify 1 -verifyCAfile letsencrypt-stg-root-x1.pem
-> Verification: OK
Simulating that only DST Root CA X3 is in the trust store:
# openssl s_client -connect expired-root-ca-test.germancoding.com:443 -servername expired-root-ca-test.germancoding.com -verify 1 -verifyCAfile letsencrypt-stg-root-dst.pem
-> Verification error: certificate has expired
Simulating that both DST Root CA X3 and ISRG Root X1 are in the trust store:
# openssl s_client -connect expired-root-ca-test.germancoding.com:443 -servername expired-root-ca-test.germancoding.com -verify 1 -verifyCAfile certs-combined.pem
-> Verification: OK
I think it's probably better to think about the situation as a Directed Graph (in the mathematical sense) in which the nodes are named public keys and the edges are certificates issued by one node. The goal of a verifier is to decide if there are a series of edges that lead from named public key they trust (e.g. ISRG Root X1) to the leaf certificate that a TLS server is showing them to prove its identity. In this understanding it is these named keys which are trusted at the root, not certificates for them.
A verifier that trusts ISRG Root X1 never needs to contemplate the "ISRG Root X1 signed by DST Root CA X3" certificate, because this represents an edge between ISRG Root X1 (trusted) and DST Root CA X3 (also trusted but soon to expire) so who cares?
It can stop once it sees just the "R3 signed by ISRG Root X1" certificate, it knows what ISRG Root X1 is, and it can verify using the public key it knows for that name that this certificate is valid, therefore R3 is trustworthy, therefore the leaf certificate is acceptable.
Unfortunately graph traversal problems are hard and so there is software that gets this wrong.
@tialaramex explains it well, though I would a caveat:
I would say "if there is a series of valid edges the lead from the the end entity certificate to any trust anchor (aka root certificate)." In other words, the path builder component of a verifier shouldn't be looking for a specific trust anchor, but for any one for which there's a path.
A couple of good but dense blog posts on the subject:
There are some Ubuntu releases that will be affected by this, whilst they are still supported or under extended security maintenance.
I've open bug reports to start tracking this issue in the affected series for openssl & gnutls28.
https://bugs.launchpad.net/bugs/+bugs?field.tag=letsencryptexpiry
I'm using Certbot to get my certs and it provide as of today:
  • fullchain.pem: leaf <- R3 <- ISRG Root X1
  • chain.pem: R3 <- ISRG Root X1
How will they look in the future?
leaf <-R3 <- ISRG Root X1 <- DST root X3 IIRC
When will the change be rolled out - I think I have seen notes about June, but apparently it has not yet taken place?
The new "long" chain is in use since May 4.
Your fullchain/chain includes R3, signed by ISRG Root X1 and ISRG Root X1, signed by DST Root CA X3. This is the current and future chain (for the foreseeable future) - no further changes.
I wonder, if between now and 2024 one could change to use a different, non-letsencrypt CA, from someone else that is both trusted by old Linux distros and old Android.
I fear of making a choice if I care more about "openssl s_client 1.0x" versus "android web browser 4.x..7.x". Cause I really don't know which has the largest impact (api usage, versus humans tap tap).
Is there a way to lookup what trust store CAs 4.x android shipped with?
If old client compatibility is your highest concern, another CA is probably your best option.
As Android 4.0+ is ~2012+, they should work fine with Sectigo's roots.
@beautifulentropy can someone else but DST sign ISRG Root X1 ? I.e. In android 7 i see GlobalSign with expiry in 2038, VeriSign until 2038, etc...
The fundamental problem is that having trust store updates is really a fundamental part of having security updates, and having any concept of a "secure connection" with a system that doesn't get security updates is an oxymoron. One can work around some issues for some amount of time with tricks like the expired-root-signature that Let's Encrypt is employing, but really the problem isn't with the CA or with the server, it's with the client that doesn't really know anymore which roots are trustworthy. (That is, if an old long-lived root somehow got its key compromised, there's no way for systems that don't get trust store updates to know about it.)
ISRG Root X1 itself only has 14 years of validity left. A system that needs to be handle secured communications over a many-year timeframe without updates really needs something different than the WebPKI can give it.
In theory, sure. But most CAs aren't thrilled with signing roots for what are basically competitors, and there's a lot of cost involved (and a lot of risk, since signing someone else's root means you're taking responsibility for everything that other root does). At this point in time, Let's Encrypt really is ready to stand on its own feet, and I'm guessing the financial/auditing/etc. requirements are too onorous for starting anything beyond their existing relationship with IdenTrust, though if somebody wanted to pay for it maybe they'd figure it out? I'm just guessing, though.
Over at Bug #1928989 “expiring trust anchor compatibility issue " : Bugs : openssl package : Ubuntu
You will find patch for OpenSSL 1.0.2g series as shipped in Ubuntu 16.04 LTS (xenial) and also a PPA built with this update for Xenial.
Testing things with it seems to make everything work. Instead of backporting all the features it really simply only sets the trusted-first flag by default. Please review these changes and let me know if anyone has any concerns about it. To me this makes openssl 1.0.2g be able to limp along with the new letsencrypt default chain, when the host otherwise trusts the ISRG Root X1 CA.
Although basic support for Ubuntu 16.04 LTS (xenial) has now ended, and only Extended Security Maintenance is offered (see Ubuntu Extended Security Maintenance | Security | Ubuntu), this issue is critical enough that openssl 1.0.2g update has now been published to xenial-security to address this compatibility issue.
https://launchpad.net/ubuntu/+source/openssl/1.0.2g-1ubuntu4.20
Xenial OpenSSL usage should thus not be affected by the upcoming change.
gnutls is currently still affected at the moment.
For gnutls I have prepared patches for Ubuntu 16.04 LTS (xenial) and Ubuntu 18.04 LTS (bionic) at
Ubuntu 18.04 LTS Bionic packages available from:
Ubuntu 16.04 LTS Xenial packages available from:
Hoping to get them reviewed and released into updates before the expiry, but not yet sure if it will happen in time.
