Project Shield integreation
Hello everyone, I’m new at this, I just installed a LetsEncrypt certificate for my website and its working fine, but now I want to use Project Shield and they ask for Public key certificate and Private key but after the validation it shows this message
My domain is: acdnicaragua.org
I ran this command: ./getssl $domain from this tutorial (https://www.inmotionhosting.com/support/website/security/install-lets-encrypt-ssl)
My hosting provider, if applicable, is: Inmotion
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): cpanel 68.0.39
If you want to use getssl, you’ll need to override the key size (DOMAIN_KEY_LENGTH) from 4096 to 2048.
Edit: I mistakenly mentioned ACCOUNT_KEY_LENGTH, but this won’t help you. Make sure you set DOMAIN_KEY_LENGTH !
